Super Duty Lug Nuts - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Super Duty Lug Nuts
Old 07-12-2004, 11:26 AM
parochoprs parochoprs is offline
parochoprs is starting off with a positive reputation.
Unhappy Super Duty Lug Nuts
OK, I serached this site and still am confused...I need factory lug nuts for my 2000 F250 4x4. Are the factory wheels hub centric or lug centric? Does anyone know where to get the lug nuts for a reasonable price? Do I need special lug nuts to attach my center caps to? The wheels are the ones that come on Excursion Limiteds. Are these 14mm? Thanks for any and all replies.
BG
Old 07-12-2004, 12:45 PM
Autobahn F-250 Lariat's Avatar
Autobahn F-250 Lariat Autobahn F-250 Lariat is offline
Autobahn F-250 Lariat is starting off with a positive reputation.
Factory wheels are hub centric not sure what size lug though someone will be along shortly
Old 07-12-2004, 01:02 PM
iskybantilus iskybantilus is offline
iskybantilus is starting off with a positive reputation.
be ware, the pitch of the lugs changed, i believe the consesus was sometimes in 2003. Found this out because my buddies wheels off his 99 wouldnt fit my 04. they changed from 14-2 to i believe 14 - 1.5 (mm) The newer ones 14-1.5 were possibly only available at the dealer? Recall the price being high, cause it was like 90 dollars or something to get all 32. 3 bucks each? The wheels are definately hub-centric.
Old 07-12-2004, 01:11 PM
n578md's Avatar
n578md n578md is offline
n578md is gaining momentum as a positive member of FTE.
I don't understand why the wheels wouldn't fit. My 2003 1/2 has the M14x1.5 lug nuts and I gave my steel wheels to a friend who is using them on a 2002 F250 with M14x2.0 lug nuts. I bought and am using aluminum wheels from a 2002 F250 with M14x2.0 lug nuts. The bolt circle from 1999-2004 is still 8 on 170mm. He kepts his lugs and I kept mine, everything still works.
Old 07-12-2004, 01:25 PM
Sorry, it wasnt that the wheels wouldnt fit. i meant i couldnt use them becuase of that. (was trying to see how his tires fit/looked on my truck) The wheels will work fine, just the lug difference.
Old 07-12-2004, 01:36 PM
n578md's Avatar
You don't like the steel wheel/wheel cover on the XL either huh? Can't blame you there. The deluxe aluminums look so much better on it. (That and the 255/75R16 33" tires too.)They should have it as an option to begin with.
Old 07-12-2004, 01:43 PM
yea. I hate the covers. thinking about just running the bare steelies, cause they look better. Havent decided if ia m gonna pick up a set of stock deluxe wheels, or splurge for the mickey thompson classic II's so i can get the 8 inch wide.
who made the powerstroke 5.4 logo? is it a sticker or a badge. can i get one?
Old 07-12-2004, 05:05 PM
n578md's Avatar
V10DOUBLETOW made it for me. He has a "POWERSTROKE V10" badge on his. It's not a real badge but an aluminum foil sticker with raised letters and lines. It looks great and seems impervious to the weather or the high-pressure carwash. I see him around the forums every once in a while. Maybe you can PM him.
Old 07-13-2004, 12:30 AM
bunnycop bunnycop is offline
bunnycop is starting off with a positive reputation.
anyone interested in a new set of Gorilla lugs (14x1.5) and new looking lugs......make me an offer
Lug Nut Sizes - 1999 vs. 2004 Oldchap 1999 to 2016 Super Duty 4 07-10-2016 12:20 PM
Wheels Type Vibrations rock2610d Excursion - King of SUVs 10 06-04-2016 09:03 AM
hub centric vs. lug centric bvanhauen 2009 - 2014 F150 3 01-03-2015 11:39 PM
Hub Centric, Nut or Stud Centric. What Years? raytasch Brakes, Steering, Suspension, Tires, & Wheels 1 02-02-2013 09:02 PM
Hub Centric Wheels CountryD 6.7L Power Stroke Diesel 4 09-05-2012 08:29 PM
Tags
1415, 14mm, 14x15, 2003, 2004, duty, excursion, ford, gorilla, lug, m14x15, nut, nuts, oklahoma, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
