Window Motor remove & replace 95 explorer - Ford Truck Enthusiasts Forums
Old 07-11-2004, 12:36 PM
hcb hcb is offline
hcb is starting off with a positive reputation.
Question Window Motor remove & replace 95 explorer
which rivits do I need to drill out to remove the window rgulator motor on the drivers door of my 95 explorer? And any other tricks necessary for replacement
Old 07-29-2004, 07:37 PM
94Explorer 94Explorer is offline
94Explorer is starting off with a positive reputation.
When I replaced the motor on a 94 Explorer there were three rivits. IWhen removing the motor from the bracket, watch out for the arm, it is spring loaded. Drill a small hole through the arm and bracket and bolt down, before removing the motor.
Back window frank5079 1987 - 1996 F150 & Larger F-Series Trucks 18 07-06-2015 04:52 AM
96 Explorer power window regulator fix tjrtmaster Explorer, Sport Trac, Mountaineer & Aviator 1 11-24-2014 12:19 AM
Window motors fordka 1987 - 1996 F150 & Larger F-Series Trucks 0 06-22-2014 05:57 PM
removeing rear slideing window vermillion95xl 1987 - 1996 F150 & Larger F-Series Trucks 2 01-15-2014 08:09 AM
Power Window Weak Or Failing, 1993 Explorer wickware Explorer, Sport Trac, Mountaineer & Aviator 9 09-08-2004 06:49 PM
Tags
1994, 2001, 2003, 95, change, explorer, f150, ford, motor, removing, replace, replacing, sport, truck, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
