So, Who is the best eletronic ignition
Speaking of ponts...
I've never had any problems with them so far. My daily driver has a 302 with points, and it works beautifully. But, I've converted to electronic a y-block using Duraspark's system parts, and a 1949 Ford 8N using another distruibutor I had laying around. I can't remember if it was a VW or a Ford 2.3 engine distributor... I didn't notice a lot of difference on the y-block after the conversion, but it made a huge difference on the 8N...
Lobo
Lobo
Lobo 2, your comments about the tractor were of interest to me. I have a 1954 Ford 600 which is my main (and only) tractor.
It is used frequently in tilling, plowing, etc. The 600 was the first overhead valve tractor engine Ford made, kind of like the Y-block, if you don't count the 1952 Lincoln versions. Mike
Hi all, thanks for the help. I had a 72 Grand Torino Sport that had points on the old 400. I ran it many years with no problems, until I bought a set of NGK plugs for it. After a thousand miles It quit. I changed the ignition to eletronic from a 76, timeing chain, carb, any thing I could thing of didn't work. then I bought a new set of chapion plugs and the car came to life. Weard?
Anyway is it possible to redo the distributior to ford eletronic by changing the breaker plate and ecentric?
thanks
Mac
thanks
Mac
Mac,
It is possible, but you must have the correct donor distributor and only one model of y-block distributor works on this setup...
There are a couple parts that you would have to change, not only the breaker plate and ecentric, a small cut on the y-block distributor would have to be made, but it works...
Lobo
Lobo
Originally Posted by Torque1st
Anything you do to replace the points is an improvement. Other than that if you can get some Ford or GM OEM boxes to work so you can have off the shelf replacements and free testing at parts stores is an improvement.
: The reason back in the 5o's and early 60"s people had trouble with Yblocks was becuase they weren't aware of their rockers being worn, and not manitaning them all that well by using non detergen oil and letting all their oil passges clog up. when ford motor comaony mad e the first 272 Yblock, those cars were mean!! It was only the clas of people around back then that messed those engines up, with the exception for some reasin 57 Yblock cars, thaey had jilions of flat spots on their crankshafts leading up to oil slinging out the rear. One thing i never understood, is why people time a engine with a slack worn timing chain to specs, when it's wasting their time??...With out oils on marker now, and understangin our rockers above must be smooth, those old setups with points won't let you down folks. You don't need all this junk (aftermarkert wise), the only way to time a car with a worn timing chain is by hand, at 1500 rpm until it's corected.And dont for get you air idle mixture screws, it matters as where the air thickness is where you live....Janet
Originally Posted by kens64
I installed a Mallory kit years ago and it was the best thing i ever did to that engine.
I think it was called the Hyfire. Dont remember what it cost.
And how do they hurt the valves?
Still no answer how an electronic ignition hurts the valves. I ran mine with as much advance possible and put over 30K on that engine and my valves are fine.
Do you know what the Mallory Hyfire is?
Yes sir, i do, but i also know with my 292 rebuilt by hand runs cool and has a beautifill medium gray spark plug color when i check, then...It does wonderfully. I constantly hear of everyone taking their engine apart in here, and why change something if it works, your cylinders will run cooler and your combustion system will last longer, with the points, and it's all you need anyway.. Yblocks have plenty of pwer....Janet
#28
I changed it because it is a better ingition system for my truck period. My 292 was rebuilt by hand also. By me and a 35 year mechanic who has run and modified Y blocks basically since they came out. One of his first cars was a 55 2 door with a 292. It didnt stay stock for long. He agreed to get it, because it was a better setup. The only way I would have problems with cylinders or my "combustion system" is if I was running it knocking and pinging all day long. Which these engines will tolerate for awhile anyway. Most engines will. The Hyfire system made it burn cleaner, started easier, and ran smoother. The soot at the tailpipes went away, telling me it was burning the fuel more completely. Never pinged, never knocked, ran cool, and made my day the moment I installed it.
I will never run points again. EVER. Why change something if it works?? Because you can get something that works BETTER. If that was the case, nobody would change from a 2 barrel to a 4 barrel, or put dual exhaust in place of a single.
2 barrel carbs and single exhaust work fine, but its more fun to let an engine breathe better.
#29
#30
Thanks, I wish you the best of luck also.
For what its worth, I did the research before buying anything, and I bought it online, so no commision there LOL. I just dont miss having to climb all over the engine trying to fix a burned set of points. I went 2 years without even removing the cap. 300,000 miles would be fantastic, hope you get there.
