What Are Best Tires For A F-250 Hd 4x4 Xlt - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-10-2004, 09:35 AM
spartan spartan is offline
spartan is starting off with a positive reputation.
Oh - I forgot. Cooper makes a really interesting tire model called the S/T. Kind of a cross between a light mud tire and an aggresive AT. If I spent much time in snow this tire would be a great choice. Does not come in 295 75 R16 size and their 315's are the biggest 315 on the market so I've ruled them out.
Old 07-10-2004, 10:18 AM
Drake12 Drake12 is offline
Drake12 is starting off with a positive reputation.
Arrow
Trying the Nitto Terra Grappler 295/75/16 right now. Balanced up and rides better than the the BFG KO's that I am used too. Does sing a little bit at higher speeds, but it has deeper treads. 40$ cheaper a tire was enough for me to try them out. If you tow or haul anything more than 30% of the time, you will not get more than 35k out of a set of BFG KO's. I have ran 5-6 sets of them over the last 3-4 years on my SD trucks and I wear them down to the very end. Now if you have a light verhicle like a half ton or SUV you can surely get 50k out of a set. My buddy just got 60k out of a set on his H2. Just depends on your application and how you treat them!
Old 07-10-2004, 01:05 PM
dougger222 dougger222 is offline
dougger222 is gaining momentum as a positive member of FTE.dougger222 is gaining momentum as a positive member of FTE.
I put just over 80,000 miles on the 99 F250 7.3 4x4 with 295 BFG ATKOS. The first set was $850 with tax and mounting, the same place wanted $940 for the same tires two years later, got them at tirerack for $740 plus $60 for mounting and such. Sears had these tires for $135 just before Christman last year.
The 285 Yokahomas are good tires as well and my budy has tons of miles on his set on his 99 1 ton 4x4 diesel and are way cheaper then the BFG's.
Old 07-10-2004, 06:26 PM
fish98f250 fish98f250 is offline
fish98f250 is starting off with a positive reputation.
I have toyo open country a/t's on my truck and have been totally satisfied with them. They were suggested to me by the tire dealer due to their snow traction rating. They come in sizes up to an E load rating and cost about the same as BFG's. They seem to be a really good all around tire. Definitely better than the GoodYear RT/S's that came on it
Old 07-11-2004, 06:45 PM
Kadukoboy Kadukoboy is offline
Kadukoboy is starting off with a positive reputation.
Hey is it true.... ( for you guys in the snow alot)....A thinner tire is better in the snow?
I heard that it has less resistance than a wider tire
Old 07-11-2004, 09:59 PM
Rugby3's Avatar
Rugby3 Rugby3 is offline
Rugby3 is starting off with a positive reputation.
yes a skinny tire "cuts" through the snow and get's down to get you the traction. Wide tires plow through it, almost hydroplaning, if you would like to call it that.
Old 07-11-2004, 10:52 PM
takerevo takerevo is offline
takerevo is starting off with a positive reputation.
bfg at is the way to go
Old 07-12-2004, 08:39 AM
Pig Pen Jr's Avatar
Pig Pen Jr Pig Pen Jr is offline
Pig Pen Jr is starting off with a positive reputation.
Quote:
Originally Posted by DS59F100
Bridestone A/T Dueller Revo AQ-II's. Rated better than BFG in water and snow handling, in treadwear longevity, and are less expensive (though still not cheap). I know many former BFG die-hards who won't go back after running the Revo's. DS
Same thing around here. I know of a bunch who switched over and swear they will never go back. Revos are definately my next tire for the 250.
Buying a USED 6.0L bismic 6.0L Power Stroke Diesel 68 07-12-2016 11:33 PM
Input Courtney Williams 6.0L Power Stroke Diesel 32 01-07-2013 10:43 AM
another 2011 - 2013 super duty fog light post ex90ranger Electrical Systems/Wiring 2 12-26-2012 08:33 PM
Useful Formulas and pointless numbers Youre welcome! STGFordCrazy04 Offroad & 4x4 30 03-30-2008 10:48 PM
Tags
20, 2004, 250, 4x4, engine, excursion, f250, gas, mud, powerstroke, recommended, tire, tires, truck, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
