How to Remove Timing Chain Cover - 4.0L pushrod Eng.? - Ford Truck Enthusiasts Forums
Old 08-09-2002, 01:40 PM
Babcore Babcore is offline
Babcore is starting off with a positive reputation.
Can anyone tell me the procedure for removing the timing chain cover on my '93 Explorer 4.0L (Pushrod Engine)?
Does it require dropping the Oil Pan?
Mine is leaking coolant...
Old 08-09-2002, 01:58 PM
adbradley adbradley is offline
adbradley is starting off with a positive reputation.
Umm,I don't think your timing chain cover should be leaking coolant since there shouldn't be any fluid in there. Better check the weep hole on your water pump since that's probably where it coming from. It's on the underside of the pump directly above the timing chain cover. If it's leaking, it's time for a water pump since that signals impending failure...
Old 08-09-2002, 04:31 PM
reberhardt reberhardt is offline
reberhardt is starting off with a positive reputation.
Old 07-10-2003, 07:54 PM
Katzen's Avatar
Katzen Katzen is offline
Katzen is starting off with a positive reputation.
Babcore -
I think I have the same problem. My '96 EB 4x4 developed an oil leak. The shop I took it to said it was the timing cover gasket that was leaking both oil and coolent.
They said that they would need to pull the motor to replace the gasket and the oil pan gasket. Cost: $1240.00
It sounds like a BIG project. Please post your results if you figure it out.
Old 07-11-2003, 07:45 AM
Opera House Works Opera House Works is offline
Opera House Works is starting off with a positive reputation.
it is the crankshaft seal on the timing cover. I just paid $8.37 for the FELPRO timing cover kit. You get the shaft seal and three gaskets that you won't need if you just replace the seal. You take the bolt out of the harmonic balancer and use a steering wheel puller. Pop out the old seal with a screwdriver. Lightly polish the balancer seal surface with very fine sandpaper. Push the new seal in. One thing I found out the hard way is there is no lip that the seal presses against. First time I pushed the seal right into the engine.
Old 07-12-2003, 01:05 PM
ssjerrys ssjerrys is offline
ssjerrys is starting off with a positive reputation.
i have a 96 explorer with the 4.0 pushrod engine also. i also thought i had a water pump leaking. bought the w/p and started to tear down and found out it was the gasket between the timing cover and the block where the coolant runs from the w/p. and yes the ford service manual says the engine must come out. i went ahead and replaced pump and retourqed the timing cover bolts hoping it would slow down leak. i also polluted the cooling system with stop leak. that has been over 2 years ago and i rarely have to put water in it.
i've heard u can sometimes pull the timing cover without pulling oil pan (i.e. pull the motor). has anyone else ever tried this with or without success.
Old 07-12-2003, 05:55 PM
My timing cover kit came with a gasket for the oil pump. ??????? I tend to believe that the cover can be removed but the oil pan gasket is damaged. You can create a gasket with silicone but how well it seals depends how well you clean the surface with brake cleaner.
Timing Chain Hydraulic Tensioner Potlicker David Explorer, Sport Trac, Mountaineer & Aviator 2 11-20-2013 03:20 PM
2003 Explorer Eddie Bauer 4.0l SOHC Timing chain cover gasket change bmusgrove Explorer, Sport Trac, Mountaineer & Aviator 2 07-10-2013 02:37 PM
99 Explorer 4.0 Timing Chains Kiroshu Explorer, Sport Trac, Mountaineer & Aviator 13 05-08-2010 12:41 AM
timing chain mwkobe Explorer, Sport Trac, Mountaineer & Aviator 14 03-14-2010 09:40 PM
Channging valve lifters/pushrods on 4.0 Rbomar 2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6 1 05-11-2004 11:10 AM
Tags
40, 40l, 93, chain, cover, engine, ford, jeep, location, push, removal, remove, removing, replace, rod, timing, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
