"norm a/c" works OK... but no "max a/c"
my "norm a/c" works fine, front and rear.... but when I select "max a/c" it seems like the air gets diverted somewhere else.... and very little comes out of the dash vents. and its not coming out of the defrost vents, so i dunno where its going! maybe to the floor?
anyone ever have this happen? whats going on?
norm a/c is ok. it works great on the freeway, but kinda piddles out in the city, so I usually run both front and rear a/c in the city driving. I need my MAX A/C!
lemme know, thanks!
lemme know, thanks!
What the MAX setting does is move a diverter/damper/flapper. Normal operation uses fresh/outside air. Switching to MAX will change to inside air like recirculating air on newer cars.
I would suspect you have a bad or loose vacuum hose that controls the damper or possibly the recirculating air intake is blocked so that no air gets to the blower which still turns but cannot blow any air. I think the air intake is under the dash on the passinger side somewhere. I have not looked for it.
Anyone else?
Anyone else?
Well, if it's coming out the floor then you have something crossed. I take it using the heat setting you get the air at the floor and in defrost mode you get it blowing on the windows right?
So going to Max A/C you hear the damper move...
I don't know. If the damper didn't move (vacuum hose off...) then the air wouldn't change at all. It sounds more like something is blocking the air intake vent. That would do it. Maybe a plastic bag got sucked up aginst the vent. That is where I'd start looking.
Tom
Tom
1993 ford
09-07-2017 09:26 AM
pete315
06-08-2010 07:42 AM
