Castor correction
Castor correction
Took my 95 in for alignment today found the camber to be off about 2.5% on each side we can put in adjustment bushings for that, but the castor measures at .1 deg on the left and abou 1.3 on the right the machine says spec for these is above 3.5. two questions
1. how did I get it this bad?
2. what can I do to fix it, they talked about differnt ball joints but that is a much as i know.
Thanks for any imput I am pretty uninformed about alignment problems.
