84 Bronco Ignition/Starter Trouble
I have an interesting problem on my 1984 Bronco. I had the engine idling the other day after changing the oil and oil sender, and was getting ready to check the timing, when the starter engaged. I shut the truck off, replaced the starter solenoid, and turned the key on, but not all the way to the start position. The starter engaged again at the key's on position, and remained engaged after the engine was running. I left the thing running, and pulled the relay wire off the starter solenoid, and the starter disengaged. I've ruled out the starter, and both solenoids that have been tried on it are good. The schematic seems to indicate that one of the wires from the control module on the distributor might be tied to the relay wire at the solenoid (which has a constant 12V with the key in the "on" position). I replaced the connector going to the control module, which was in pretty bad shape, and the problem still persists. I'm down to either the ignition switch or the control module. Am I on the right track with this? Has anyone ever had this problem?
It started this, out of the blue, with a solenoid that had been on there a while. It started yesterday. I changed the connector on the control module today, and the thing worked great the first time I cranked it. I put up the tools, and wanted to check one more time before coming in the house, and it started again. I'm gonna check again tomorrow, but it gives me the feeling that the first cold start will go fine, and it goes down hill from there. Unless something reset when I disconnected the module to replace the connector. I don't know. I'm fishing, I guess. I've never seen one do anything exactly like this.....
Ok. Here is the final resolution. I replaced the ignition switch today. The problem persisted. I got a bright idea to hook my meter up to the red/blue relay wire on the front of solenoid, with the wire disconnected from the solenoid. I turned the ignition on, and got 12 volts. While watching the meter, I started squeezing the wiring harness, and shaking, and the sort. Close by the control module that's on the distributor, while checking the harness, the 12v went away. I wiggled again, and it came back. I stripped back the tape and started checking individual wires, and found a huge short on the red/blue wire that appears at the module, and at the solenoid. I fixed all the shorts, reconnected all the harness connections, and the trouble cleared.
1998-Expedition
1997-2006 Expedition & Navigator
15
03-05-2020 01:29 PM
jdhudall
24
05-19-2017 10:55 AM
KShults
1999 to 2016 Super Duty
10-04-2016 07:40 AM
ironelk
Electrical Systems/Wiring
12-03-2005 10:29 PM
Stephen_E
05-09-2004 01:50 PM
