Engine Swaps
Engine Swaps
Being new to the forum, I have enjoyed reading the "stickeys" regarding rear end swaps and front suspension alternatives. Is there a similiar compilation back in the archives regarding various drive line swaps? Ie ease of installation, frame modifications required, motor mount availability. I have a donor truck with a warmed up 302 and AOD for my 54. Is there a source that I can review common problems / solutions with this type installation? thanks in advance
Pig
Pig
Plan is pretty simple. Keep the straight axle, lower a couple inches with springs (looking hard at the options at Midfifty), add the toyota p/s conversion(stock column), add power brakes (debating disc vs ceramic shoes), drop in the 302/AOD & 9" from the donor truck. Probably a given, but I'll ask: do the front and rear engine cross supports from the stock drivetrain need to come out before I add the new mounts, or will everything fit and you leave them in for frame strength? Thanks for all the advice. - Pig
