WOW, perfect for what I was looking to find out. THANK YOU for keeping and sharing such a detailed log of your efforts. One additional question; What did you use to punch out the pin? thanks
Umm, I used a punch. Is this a trick question? Seriously though, Dad had a punch that was the perfect size to drive out the rolled pin. Is that the pin you are asking about?
I'm glad you found the web page useful. That's why I take the time to document these things.
Sorry, not a trick question. Just my normal over-complication of a simple problem. I thought it may have required a special tool or punch to get it out. I bought a set of punches last night and will try to remove tonight. Thanks for your help. - Pig
Kevin, worked out just like the pictures you sent. Thanks a million. I spent all day monday trying to figure this out. The job was done in 10 minutes with your help. Thanks again.
