Explorer is leaning to the left :( - Ford Truck Enthusiasts Forums
Old 09-07-2002, 01:29 AM
zoti's Avatar
zoti zoti is offline
zoti is starting off with a positive reputation.
Hi,
I have noticed a weird "thing" on my explorer ('98 4WD 4.0L SOHC - 45K). The truck seems to be leaning a bit to the left. If I measure the space between the rear right wheel to the body (from the center to the body - the part above the wheel) and compare it to the left I find that there is a difference of almost one inch. It seems like the truck is "leaning" to the left. It is less noticeable on the front but there is a difference there as well.
The truck doesn't seem to have had any accident (I bought it second hand from the original owner). I looked under the back of it and there isn't any damage visible. All looks in place. The only thing I might have noticed is that the rubber parts that connect the stabilizer arm to the stabilizer bar on the right side seem to be a bit off. But not to a level that will cause such a difference.
I will grab my camera tomorrow and add some pictures of the whole situation.
Any thoughts are appreciated.
Old 09-07-2002, 12:37 PM
zoti's Avatar
Pictures can be found on
http://www.pbase.com/zoti/explorer
Thanks for your help.
Zoti
Old 09-07-2002, 01:53 PM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
Was the previous owner overweight?
Old 09-07-2002, 04:58 PM
Dialtone Dialtone is offline
Dialtone is gaining momentum as a positive member of FTE.
Could your rear shocks possibly be gas charged with one of them giving up the ghost? Try disconnecting both lower shock mounts and re-measure the height. If both side measurements are close, then you definately have a weak shock absorber on one side, if not then a weak spring.
Dialtone
Old 09-07-2002, 10:49 PM
zoti's Avatar
No, the guy was not FAT. ;-)
How can I tell if the shocks are gas ?
If it's a spring, What can I do ?
Zoti
Old 09-07-2002, 11:23 PM
Gas charged shocks will fully extend on their own if unrestrained. Most shocks nowdays are gas charged to some extent.
I have seen many vehicles with a weak coil spring or two. Only good solution is to replace them (replace them in pairs for a good match). Leaf springs generally not as susceptable to sagging unless constantly overloaded and stressed. If your is a leaf assembly, you may be able to install a spacer between spring and axle tube to raise the low side or drop the high side depending if you have spring over axle or spring under axle, but would be better to get a replacement pair.
Dialtone
Old 09-08-2002, 12:10 AM
nightri1 nightri1 is offline
nightri1 is starting off with a positive reputation.
how much do I really need the Steering Stabilizer? jackstraw 1999 - 2003 7.3L Power Stroke Diesel 11 07-20-2015 09:43 PM
BDS Dual Stabilizers (99-04) Review A/Ox4 1999 to 2016 Super Duty 8 07-05-2014 06:30 PM
2000 Explorer Leans Left ptwohey Explorer, Sport Trac, Mountaineer & Aviator 10 03-20-2014 10:02 AM
Truck Leaning ?? Trophy_23 1999 to 2016 Super Duty 10 12-18-2011 02:21 AM
Body Lean??? 04 F250 Bear_Hunter 6.0L Power Stroke Diesel 1 04-15-2004 10:25 PM
Tags
02, 2002, 2006, 96, b2300, bigger, end, explorer, f150, ford, leaning, leans, left, mazda, rear, side
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
