HELP - Sucking noise behind the dog house...!!! - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 07-05-2004, 01:51 PM
LimeyZ LimeyZ is offline
LimeyZ is starting off with a positive reputation.
Unhappy HELP - Sucking noise behind the dog house...!!!
I have a weird air sucking noise that seem to be coming from behind the dog house. It's most noticeable during acceleration. The noise may have always been there from when I bought the van but now it has become louder and very annoying! I can hear it swithing on and off during accel/decel.
I thought it may have been the either the bypass or diverter valves in the thermactor system since they are both just behind the dog house. These valves both hold a vacuum okay so the diaphrams must be okay. I have not check that engine is supplying a vacuum - I guess I probably should check this.
Anyway, engine runs fine, pulls hard and is not throwing any codes. Anyone have any thoughts/checks/ideas on this condition before it drives me nuts?!
Paul
1995 E150 conversion 351 55K miles
Old 07-05-2004, 04:28 PM
trike1946's Avatar
trike1946 trike1946 is offline
trike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud of
I usually try spraying some carb cleaner at the gaskets and vacuum lines to look for a leak. If you hit one the engine will change rpms.
Old 07-05-2004, 05:29 PM
yodoc40 yodoc40 is offline
yodoc40 is starting off with a positive reputation.
Is it fuel injected or carberated? On some engines with carbs, the carb can come loose from the mounting plate and cause a sucking noise. Have you seen a drop in fuel economy? Any transmission slippage? It could be a vacuum modulator, a worn out vacuum line, a bad vacuum pump, etc... I would need more info to be able to give any other ideas
Old 07-05-2004, 09:56 PM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
It could also be a bad PCV valve.
Tags
dog, doghouse, ford, makes, noise, noisy, sucking, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
