Prep and Paint truck topper - Ford Truck Enthusiasts Forums
Old 07-05-2004, 11:22 AM
pkweed pkweed is offline
pkweed is starting off with a positive reputation.
I have a fiberglass truck topper that I want to paint. How should a prep it and what paint to use, the most inexpensive way. Also what type of paint to use. Thanks. Paul
Old 07-05-2004, 04:38 PM
trike1946's Avatar
trike1946 trike1946 is offline
trike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud oftrike1946 has much to be proud of
Steel wool, wipe with laquer thinner, primer and paint. Pep Boys fine, and it will match the truck if you want.
Old 07-05-2004, 07:21 PM
Will an enamel paint work, or do i need a special paint?
Old 07-06-2004, 01:03 PM
Aekisu's Avatar
Aekisu Aekisu is offline
Aekisu is starting off with a positive reputation.
<cr>
Enamel will work. Prep is very important. Before you start, scrub with dishwashing soap and water. Dry and degrease with a wax/greaser remover (don't use lacquer thinner). Scuff sand with 400. Don't sand through the gelcoat. Use a red Scrotch-Brite pad for those hard to get areas. Degrease again. Spray your favorite enamel.
Old 07-06-2004, 02:17 PM
Thanks for the good word!!
Old 09-23-2004, 07:04 PM
jdon88 jdon88 is offline
jdon88 is starting off with a positive reputation.
I am about to repaint a fiberglass cap with a different color, old color is moroon and new color will be dark blue. Do I need to primer before painting color? I'm using acrylic enamel. Also there are a few small chips in it, can I fill with body filler or fiberglass resin? Thanks.
Truck Topper Questions DCP Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 6 03-15-2017 01:55 PM
Topper compatibility terrypearson 1999 to 2016 Super Duty 8 05-23-2013 04:39 PM
Topper/canopy...what fits 89F1fiddy 2004 - 2008 F150 5 08-23-2011 09:10 PM
Shortbed camper shell/topper guitarpicr 1999 - 2003 7.3L Power Stroke Diesel 1 03-29-2010 06:52 PM
Topper Repair Hawkdriver Paint & Bodywork 1 09-16-2003 07:47 PM
Tags
cap, fiberglass, fibreglass, filler, francisco, needed, paint, painting, repaint, repainting, spray, top, topper, toppers, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
