Flathead in a Model A - Ford Truck Enthusiasts Forums
Old 07-05-2004, 01:30 AM
90ebbronc 90ebbronc is offline
90ebbronc is starting off with a positive reputation.
Yes i know this is a truck site, but who cares, lol. Im looking for a model A. Im wanting to make it into sorta a rat rod. Just about everyone you see that is a hot rod, has a small block chevy in it. Well i dont believe in cross breading like that. I have found a flathead v8, and would really love to put it into the Model A.
Ok my question is, would i have to do anything to the frame to hold up to the flathead. Or should the frame be strong enough to hold the flathead, plus not twist under its "huge" lol power. I figure if all else fails, i can box in the original frame, no biggie. I just want to keep most of the car original, for the exceptions of the flathead and power steering and of course the tranny and rear end. I guess you could say, that i want the body, frame, and possibly the front susp (if at all possible to do and still have power steering). If thats not possible, then please make suggestions for a front end and still keep solid axle. This will be driven every day thats its pretty, and on weekends. Basically this will be a second daily driver, just not driven as often as the Bronco (there is my ford truck so i wont get kicked out LOL).
Thanks for all the help, and sorry for the long book.
Old 07-05-2004, 02:38 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
You'll get a better response at one of the following:
http://www.fordbarn.com/
http://groups.msn.com/FordFlathead19...pgmarket=en-us
Old 07-05-2004, 04:36 PM
Thanks for the links. Also can you run unleaded gas in a flathead, or should you buy the lead additive for it?
Old 07-05-2004, 08:26 PM
Overkill-F1's Avatar
Overkill-F1 Overkill-F1 is online now
Overkill-F1 is starting off with a positive reputation.
I don't think you should worry about lead additive for the valves/seats in a Flathead.
...Terry
Old 07-05-2004, 10:21 PM
So flatheads can run on unleaded gas without any problems?
Old 07-05-2004, 11:50 PM
SP_51-F1 SP_51-F1 is offline
SP_51-F1 is starting off with a positive reputation.
Yeah, they will run just fine.
Old 07-06-2004, 01:19 AM
Awesome news to hear. Ok so now what about dropping it into a Model A, very many modifications to the frame to do so?
Old 07-06-2004, 10:30 AM
mtflat mtflat is offline
mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.mtflat has a good reputation on FTE.
I'm not aware anyone here has done this mod, but 4tl8ford gave you the two best links to ask this question. Mike Bishop haunts both and has a book out about the transplant.
Old 07-06-2004, 03:24 PM
whats the book called?
Old 07-07-2004, 11:14 PM
Kyfireman Kyfireman is offline
Kyfireman is starting off with a positive reputation.
Its something like "How to build a Hot Rod Model A" or "How to build a traditional Hot Rod" something like that. Do a search on Amazon for the author "Bishop" and "Tardel" They are like $15.00 on Amazon Good luck!
Front end pop clicks etc doublecanister 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 06-26-2014 03:09 PM
239 flathead 51 ford f2 (swap?) 3rdshiftDiscretion 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 06-18-2011 06:08 PM
1951 F2 magicmanwon 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 04-14-2010 09:42 AM
flathead 6 in a 51 f1 or drop in a v8? ford5t6 Flathead V8 & Flathead 6 6 12-22-2006 04:26 PM
289 or 302 in 48 F1?? restoringmy46 1948 - 1956 F1, F100 & Larger F-Series Trucks 24 10-25-2006 10:15 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
flat, flathea, flathead, ford, frame, head, model, modifications, power, put, putting, steering, transplant, unleaded, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
