pertronix ignition system
Ken, the easiest way to check the spark voltage is to simply look at the spark. Take a spare plug and attach a wire to it and then ground it to the block. Then look at the spark when an assistant turns the engine over. You're looking for a bright blue/orange spark with a nice "pop".
The Pertronix is a triggering device, so if the plugs are sparking at all, it's working. The spark intensity is determined by the coil. If you have a weak spark, I would suspect the coil being weak, or maybe low voltage going into it.....
the voltage to the + side of the coil is about 12.6 volts
It's easy to splice in a universal external resistor in the coil (+) wire, if you need to.
If you have an ohmmeter, check the ohms across the 2 smaller (+ and -)terminals. It should be less than 2-3 ohms. Then check the ohms across a small terminal and the larger distributor output terminal. IIRC, it should be about 10-12K ohms. If the coil is weak, you'll have a very large ohm reading at this point...........
I ran the pertronix in my 400M for a couple of months, and my dad ran one on his 360FE for about a year. The problems we had were hard starting in cold weather and just a lack of solid power at times. What we did was replaced the setup with Ford Duraspark setup. You can take the whole system out of a mid to late 70's vehicle with the same motor. Just get the complete harness and the box and distributor (if you want to rebuild) and coil or buy a new distributor and coil. You'll have to run power to it in the key on and key start positions and mount everything. It made a huge difference on both of our vehicles performance wise, plus it looks factory.
Another benefit is if anything breaks down, you still are using parts that are readily available at any auto parts store, try that with the pertronix.
Brian
Brian
52 F1 Stocker
10-14-2016 10:40 AM
Mercmeister
01-09-2013 08:06 AM
