heater hose routing. 302, help please.. - Ford Truck Enthusiasts Forums
Old 07-04-2004, 12:08 PM
packrat56's Avatar
packrat56 packrat56 is offline
packrat56 is starting off with a positive reputation.
I thought I would remember where they went, must be getting old! LOL
I have a 302 from the 70's, there are two outlets on the water pump for heater hoses, and one on the thermostst housing. There is a fitting on the manifold and two heater hoses on the firewall (in a 56 f100) an upper hose and a lower. Anyone have any diagram, or can anyone take a look at their smallblock and bail me out??
Old 07-04-2004, 12:22 PM
xltlariat87 xltlariat87 is offline
xltlariat87 is starting off with a positive reputation.
not real sure,but should be one hose coming from the heater core to the water pump,
another hose from the heater core to the intake, the other hose on the water pump should be a bypass hose that goes to thermostat housing.
Old 07-04-2004, 06:39 PM
packrat56's Avatar
Anyone have a diagram?
Old 07-04-2004, 11:14 PM
Beast12's Avatar
Beast12 Beast12 is offline
Beast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant futureBeast12 has a brilliant future
If your engine is the same as mine (a 85 302 EFI) there are 2 spots on the water pump for heater core hoses. The upper one goes from the waterpump to the thermostat housing (bypass hose) and the lower one goes to the heater core (right side I believe, if looking from the front of the truck). The other heater core hose goes to the engine. Hope this helps.
-Matt
P.S. I may be wrong but I don't think it matters what heater core hose goes where. Just make sure you have the bypass hose right.
Old 07-04-2004, 11:17 PM
packrat56's Avatar
Thanks! I appreciate the help...
Old 07-04-2004, 11:18 PM
Beast12's Avatar
No problem. Let us know how it turns out!
-Matt
302 Heater Hose Routing Rick_Fury 1973 - 1979 F-100 & Larger F-Series Trucks 7 11-20-2011 01:51 PM
Heater Inlet Hose Mohave Modular V10 (6.8l) 5 09-11-2009 11:07 AM
53 Heater Pappys53 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 11-07-2008 05:11 PM
Heater hose route gabocar 1997-2006 Expedition & Navigator 3 07-26-2008 08:57 PM
heater hose diagram, please help.. packrat56 Cooling, Heating, Ventilation & A/C 0 07-04-2004 07:10 PM
Tags
302, bypass, ford, hose, routing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
