Popping noise in steering wheel area - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 07-04-2004, 12:39 PM
Antelope V-10 Antelope V-10 is offline
Antelope V-10 is starting off with a positive reputation.
Once in a while I have a popping noise in my steering wheel area when I turn and even sometimes when taking off from a stop. The dealer couldn't get it to do it enough to make a diagnosis. I have greased the steering linkages, retorqued sway bar and brackets, shocks, and wheels. Anyone else with this noise? Thanks, Antelope V-10
Old 11-28-2004, 01:53 AM
keith w's Avatar
keith w keith w is offline
keith w is gaining momentum as a positive member of FTE.keith w is gaining momentum as a positive member of FTE.
I know it has been a long time since you posted this, but did you ever figure out what the popping was coming from? I have no idea if the noise my truck makes is similar to yours or not, but it seemed close in the description. It isn't really so much an audible sound as it is a just a light thump. It does not feel like a deep thump either, more like it is in the steering wheel area.
Old 11-28-2004, 10:44 AM
I still have the popping. The dealer wouldn't listen to where I thought it was so they replaced the steering shaft and gear box but it is still there. If I put my hands at 3 and 9 o'clock and push alternately back and forth then do the same at 6 and 12 o'clock I can get it to pop. I took the cover off of the column and see a spring and washer set-up so maybe that's where it is coming from. Our service truck at work does the same thing so I kind of quit worring about it.
Old 11-28-2004, 01:56 PM
keith w's Avatar
You know I have done that too, pushed back and forth on the steering wheel to try to get it to replicate it, but so far, I haven't been able to get it to make the same noise. I have a feeling it might be in the tilt mechanism.
Old 11-28-2004, 07:39 PM
Well hopefully between the two of us we can find out what it is.
Code Reader/Scanner Antelope V-10 Modular V10 (6.8l) 11 08-05-2008 05:46 PM
ZooDad Antelope V-10 Modular V10 (6.8l) 15 02-25-2007 10:44 PM
? for guys with headers Antelope V-10 Modular V10 (6.8l) 27 08-26-2006 02:18 PM
Stan's Y-pipe is in !!!!!! Antelope V-10 Modular V10 (6.8l) 28 12-24-2005 12:47 AM
front driver side clunking/popping HaroldCallahan Ranger & B-Series 6 09-01-2005 08:22 PM
Tags
08, coming, crackling, f150, f250, f350, fabtech, ford, noise, noises, popping, sound, steering, sterring, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
