C6 cooling lines... - Ford Truck Enthusiasts Forums
C6 cooling lines...
Old 07-03-2004, 10:42 PM
53fatfndr's Avatar
53fatfndr 53fatfndr is offline
53fatfndr is gaining momentum as a positive member of FTE.53fatfndr is gaining momentum as a positive member of FTE.
C6 cooling lines...
Just wondering, is it possible to just use high temp/pressure rubber hoses for my cooling lines for my '71 C6, with flared fittings?
Also, which lines are which? I have 2 threaded holes on the passenger side of the tranny and I'm assuming that the forward most hole is the "sending" line and that the back most hole is the return line??? It's been years since I tore down this engine tranny combo, that I've forgotten where some of the parts go
Old 07-04-2004, 02:49 AM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
yes I have used fuel line to connect the hard line to a extra cooler, it's not the best but you can do it, but remember rubber line causes more friction or restriction than hard line but I use stainless braided line on my race truck
yes the front is the sending line, and the rear is the return
C-6 cooling line pressure beartracks Clutch, Transmission, Differential, Axle & Transfer Case 2 06-27-2014 03:22 PM
please help transmission line scoots97f150 1997 - 2003 F150 1 06-21-2010 06:04 PM
Radiator problems. woodn1 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 03-11-2010 08:51 AM
want to put trans temp gauge on C6 buffalobob Clutch, Transmission, Differential, Axle & Transfer Case 2 11-21-2007 12:32 PM
Tranny oil lines 4x4_EB_Explorer Explorer, Sport Trac, Mountaineer & Aviator 3 03-18-2002 10:40 AM
Tags
c6, cooling, line, pressure
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
