Airbag sensor check help needed
Hi folks, this is my first post here. I have a '96 E150 w/ a 5.8L V-8 and 76K miles on it. My airbag light is flashing a 44 code, I have checked the continuity at the module under the dash and that is OK. My question is, how do you check the frame mounted sensor for continuity? The material that I read said to check it at the connector at the top of the sensor but, I can't see any way to take it apart. I don't want to pay for a new sensor if it's not necessary. Thanks for any help that you can give.
