Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty And Heavy Duty
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Super Duty And Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 07-03-2004, 10:46 AM
Rancha9's Avatar
Rancha9 Rancha9 is offline
Rancha9 is starting off with a positive reputation.
Fuse panel diagram?
Anybody have a fuse panel diagram for a 2000 F-250 with the PSD? Mine came with no manual, and the Haynes I just picked up doesn't have it either...
__________________
2003 F-250 XLT, 4wd 7.3L, aka The Bus
MODS:
BTS Valve body
Ford AIS system
5 inch "BFE" system
20" KMC Rockstars with Nitto Terra Grapplers
New springs in front, new shocks all around
  #2 (permalink)
Old 07-03-2004, 11:22 AM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.
Interior Fuse Panel
Fuse/Relay
Location
Fuse Amp
Rating
Passenger Compartment
Fuse Panel Description
1 20A Turn/Hazard Lamps
2 10A Airbag Module
3 20A Cigar Lighter, Data Link Connector
4 10A Glove Box Lamp, Map Lamps, Power
Mirrors, Underhood Lamp
5 — Not Used
6 — Not Used
7 5A Power Window/Lock Switch Illumination
8 5A Radio, Headlamp Switch Illumination
9 — Not Used
10 15A Dual Fuel Tanks
11 30A Wiper Motor, Wiper Run/Park Relay Coil,
Wiper Hi/LO Relay Coil, Washer Pump
Relay Coil
12 15A Horn
13 20A Stop Lamps, Center High-mount Stop
Lamp, Trailer Tow Stop Lamp, Speed
Control
14 10A Dome Lamp, Cargo Lamp, Courtesy Lamps,
Running Board Lamps
15 5A Stop Lamp Switch (Logic): Generic
Electronic Module (GEM), Powertrain
Control Module (PCM), Four Wheel
Anti-lock Brake System (4WABS) Module,
Brake Shift Interlock, Cluster and PCM
Keep Alive Memory
16 15A Instrument Cluster, Hi-beam Headlamps
17 — Not Used
18 — Not Used
150
Fuse/Relay
Location
Fuse Amp
Rating
19 10A Auxiliary Powertrain Control Module
(APCM) (Diesel only), Instrument Cluster,
GEM Module, Overdrive Cancel Switch, Idle
Validation Switch (Diesel only), Overhead
Console, Diesel PCM via Clutch
20 15A Starter Motor Relay Coil, Clutch Switch
21 — Not Used
22 10A Air Bag Module, Passenger Air Bag
Activation/Deactivation Switch, Blower
Motor Relay Coil
23 — Not Used
24 10A A/C Clutch, Blend Door Actuator, Trailer
Tow Battery Charge Relay Coil, Four Wheel
Anti-Lock Brake System (4WABS), Turn
Signal
25 — Not Used
26 — Not Used
27 10A Ignition Run Power Feed (Customer Access)
28 10A Brake Shift Interlock, DRL Relay Coil,
Speed Control Module, Backup Lamps,
Trailer Tow Backup Lamp Relay Coil,
Electronic Shift On The Fly Hub Lock
Solenoid, Vacuum Pump Motor
29 5A Instrument Cluster (Charge and Airbag
Warning Lamps)
30 30A PCM Relay Coil, Ignition Coil (Gasoline
only), Fuel Heater (Diesel only), Wastegate
Solenoid (Diesel only), Injector Driver
Module Relay Coil (Diesel only)
31 — Not Used
Relay 1 — Interior Lamp Relay
Relay 2 — Not Used
Relay 3 — Horn
Relay 4 — Power Window One Touch Down Relay
Relay 5 — Accessory Delay Relay
Under hood power distribution box
Fuse/Relay
Location
Fuse Amp
Rating
Power Distribution Box Description
1 7.5A * Trailer Tow Left Stop/Turn Lamp
2 10A* Washer Pump
3 7.5A* Trailer Tow Right Stop/Turn Lamp
4 20A* Trailer Tow Backup Lamps, Trailer Tow
Park Lamps
5 20A* (Gasoline
only)
5A* (Diesel only)
Gasoline only-PCM, Fuel Pump Relay Coil,
Mass Air Flow Sensor, Fuel Injectors
Diesel only-Dual Alternator A Field
6 10A* Gasoline only-A/C (CASS)
Diesel only-Single or Dual Alternator
A Field, Regulator
7 20A* (Gasoline
only)
5A* (Diesel only)
Gasoline only-Vapor Management Valve,
HEGO Sensors, Intake Manifold
Communication Control, EVR Solenoid,
PCM, Canister Vent Solenoid
8 15A* Trailer Tow Electronic Brake
Illumination, Park Lamps, Trailer Tow
Park Lamp Relay Coil
9 10A* Left Headlamp (Low Beam)
10 20A* Power Point
11 10A* Right Headlamp (Low Beam)
12 15A* Daytime Running Lamps (DRL)
Resistor
13 30A** Multi-function Switch, Headlamps
14 60A** Anti-Lock Brake System
15 — Not Used
16 30A** Trailer Tow Battery Charge
17 30A** Electronic Shift On The Fly Relay,
Transfer Case Shift Motor
18 30A** Power Seat
19 20A** Fuel Pump Motor, PCM
20 50A** Ignition Switch (B4 & B5)
153
Fuse/Relay
Location
Fuse Amp
Rating
21 50A** Ignition Switch (B1 & B3)
22 50A** Junction Box Battery Feed
23 40A** Blower Motor
24 30A**
(Gasoline only)
20A**
(Diesel only)
PCM Power
25 30A*** Power Windows
26 20A** If equipped with Remote Keyless
Entry-Driver Door Unlock Relay Coil,
All Door Unlock Relay Coil, All Door
Lock Relay Coil, Park Lamp Flash
Relay, If not equipped with Remote
Keyless Entry-Power Door Lock Motors
27 - (Gasoline only)
30A**
(Diesel only)
Gasoline only-Not Used
Diesel only-Injector Driver Module
28 30A** Trailer Tow Electronic Brake Controller
29 20A** Radio
30 -- PCM Power Relay
31 -- Blower Motor Relay
32 -- A/C CASS (Gasoline only), Injector Driver
Module Power Relay (Diesel only)
33 -- Washer Pump Relay
34 -- Windshield Wiper Park/Run Relay
35 -- Windshield Wiper HI/LO Relay
36 -- A/C Clutch Diode
37 -- PCM Diode
38 -- Trailer Tow Backup Lamp Relay
39 -- Trailer Tow Battery Charge Relay
40 -- Electronic Shift On The Fly Relay #1
41 — Electronic Shift On The Fly Relay #2
__________________
My advice is just advice..Its free "IF THAT DONT FIX IT, SOMETHING ELSE WILL"
IF IT AINT BROKE DONT FIX IT!!
My Missing Michelle
  #3 (permalink)
Old 07-03-2004, 11:39 AM
hang10's Avatar
hang10 hang10 is offline
hang10 is starting off with a positive reputation.
I don't need a diagram, I don't even have a PS but I continue to be impressed by what people here on FTE will do to help others out. Great job HomerWinzlow. Thanks for taking the time to do this.
__________________
Old fishermen never die, they just smell that way.
  #4 (permalink)
Old 07-03-2004, 11:42 AM
Rancha9's Avatar
You are awesome, Homer... Thanks a million!
__________________
MODS:
BTS Valve body
Ford AIS system
5 inch "BFE" system
  #5 (permalink)
Old 07-03-2004, 12:46 PM
Glad to help when I can..
__________________
My Missing Michelle
  #6 (permalink)
Old 02-11-2008, 09:33 PM
stopperdch stopperdch is offline
stopperdch is starting off with a positive reputation.
can anyone tell me where:
are located on a 2001 F250 superduty? The above diagram is the only one i can find but it excludes those two...
  #7 (permalink)
Old 02-11-2008, 09:49 PM
If you are looking for the relays themselves there is a separate trailer tow relay block under the hood near the driver firewall. There is probably two small two relay boxes. That is provided the persons whom owned it when new installed them from the accessory packet that came with the vehicle.
If you just need to know the fuse numbers for 2001, it is maxi fuses 16 and 17 in the power distribution box.
__________________
My Missing Michelle
  #8 (permalink)
Old 02-11-2008, 11:21 PM
rbaker6336's Avatar
rbaker6336 rbaker6336 is offline
Redneck Has Been
rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE. rbaker6336 has a great reputation on FTE.
you can download your owners manual here https://www.fleet.ford.com/maintenan...ls/default.asp
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install, DooDad???=(dfuser ram air)
'98 Grand Cherokee, '86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
  #9 (permalink)
Old 02-12-2008, 10:31 AM
94yj 94yj is offline
94yj is starting off with a positive reputation.
but take out the s
  #10 (permalink)
Old 01-21-2009, 02:42 PM
SOCOM3WARRIOR SOCOM3WARRIOR is offline
SOCOM3WARRIOR is starting off with a positive reputation.
Thank you thank you
  #11 (permalink)
Old 01-21-2009, 06:54 PM
Beerstalker's Avatar
Beerstalker Beerstalker is offline
Beerstalker has a very good reputation on FTE. Beerstalker has a very good reputation on FTE. Beerstalker has a very good reputation on FTE.
You can also download them for free at www.motorcraftservice.com
Click on Owner's Guides on the left and then enter your vehicle info.
__________________
2007 F350 Lariat, CC, LB, 4x4
4.5" DR Lift w/35x12.5r20 Toyo Open Country M/Ts
Keystone Restyling Ram Air Hood W/Airaid Intake & Pre-filter
Recon Smoked Cab, Mirror, and Brake Lights
MSD Dashhawk w/A Pillar Mount
Dieselsite Coolant Filter
Lund Eclipse Window Vents
Weatherguard Toolbox
  #12 (permalink)
Old 07-19-2009, 08:44 PM
chrisf chrisf is offline
chrisf is starting off with a positive reputation.
Thanks for the diagram Homer. A good post long after it was written.
  #13 (permalink)
Old 11-01-2009, 08:28 PM
Bluerhino13's Avatar
Bluerhino13 Bluerhino13 is offline
Bluerhino13 is starting off with a positive reputation.
Quote:
Thanks for that website. I have been trying to find someplace that I could find the owners manual for fuse pannels. And Ford Truck Enthusiasts web site just keeps giving help. Thanks
Tags
02 , 03 , 2004 , 2007 , battery , box , charge , diagram , drive , f150 , f250 , ford , fuse , panel , relay , trailer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Fordฎ is a registered trademark of the Ford Motor Company.
