Twin pumpkin front diffs, dual front driveshafts, twin I-beamish 4x4 van conversion??
I'm at a loss, someone please explain?
http://cgi.ebay.com/ebaymotors/ws/eB...483581967&rd=1
Only one pic of the front end, but... but... but...
Interesting link!
How do you do two front diffs? Turn a tandem transfer case backwards hooked to a full time transfer case? Hence, only AWD and locked 4x4?
To me it looks like the front diffs are welded to the stock I-Beams! Does this mean in 4x4 lock you have a locked front end? The only way to get a normal diff to work in that setup is to lincoln lock it each diff. To me they look like two different Chevy diffs on each side ...
You know what is really funny? Bragging about putting three tons of wood in a one ton van, in a van with no barrier between the load and driver, and driving it in slippery conditions.
Be interesting to know how it was thrown together.
When I first read this post I said say whaaaat?
Then I did a search. Here are a few Pictures:
https://www.ford-trucks.com/user_gal...oid=47643&.jpg
https://www.ford-trucks.com/user_gal...oid=47644&.jpg
https://www.ford-trucks.com/user_gal...oid=47645&.jpg
Kinda weird but cool
Originally Posted by faroffthetrack
The point of that conversion is.......
Last edited by IB Tim; 12-12-2004 at 10:15 AM. Reason: Language "like a crack smoking project"
Looks like someone's method of converting a 2wd truck to 4wd without changing the whole frontend and lifting the truck. I've never seen a transfercase with dual front outputs, let alone angled like that. The diff cases are unusual too. I dont really see the benefit to it though, plus it adds alot of unsprung weight to the independent frontend and alot of extra parts to maintain/replace...
