i thought the wrist pins in a 390 were pressed in with a press and could not move but instead there is 2 clips on both ends 2 of which broke in different cylinders and let the wrist pin go into the cylinder wall a ruin the block
There's difference between Spiro-locs and C clips. Spiro-locs are just that, spiral wound flat springs that replace the C clips that are known to break. Had C clips come loose in my 427, also grooved one cylinder wall, but had it sleeved. In response to ford390gashog's original question, all FE's had the C clip retained pins, better known as Floating Pins. Most of the better high performance engines have this feature.
