300 Timing Gear Broke
"Old Blue" died on me for the first time yesterday. I was on my way to work cruising about 55 when she let out a belch and coasted to a stop. I pulled the distributor cap off and while cranking it and noticed the distributor wasn't rotating. After having it towed home, I removed the front cover and found the source of my woes. The phenolic timing gear was rounded off where it meshes with the crankshaft pulley. This phenolic timing gear was new about 35K miles ago when it was overhauled. I suspect the camshaft was binding or seized internally but that is just speculation at this point. Should I replace the camshaft to be on the safe side? What about the camshaft bearings? Would the engine have to be disassembled to gain access to the camshaft bearings? Or, would it be cheaper to have the engine swapped out with a rebuilt? I bought this truck new in 1983 and could never part with it.
Would greatly appreciate some advice from some of you pro's out there. Thanks.
cargo e150
11-05-2010 05:20 PM
jaded_prince2002
11-18-2003 06:30 AM
