Ignition Cylinder Removal - Ford Truck Enthusiasts Forums
Old 09-21-2002, 06:35 PM
Droptopfiveo Droptopfiveo is offline
Droptopfiveo is starting off with a positive reputation.
I have a 94 ford explorer and I'm tring to remove the ingnition Cylinder in the steering colum. There is suppose to be a push rod or pin you press in while the key is in the run possiton and then it should slide right out. The problem is I can't find the pin to push in so that the cylinder can be removed. This is a 94 ford exploer I've looked all around the cylinder and I still can't find this damn thing. Any help would be appreciated.
Old 09-21-2002, 06:38 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
Welcome to FTE!
Unfortunately you have posted this Question in the general Cconversation forum,where tech questions aren't allowed.
Please post your question in the corresponding forum to your question.
In your case, that would be the Explorer forum.
You might take some time and cruise around the web site to see where everything goes.
I will move it over there.
Again , Welcome to FTE!
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old 09-21-2002, 08:27 PM
Dialtone Dialtone is offline
Dialtone is gaining momentum as a positive member of FTE.
You are in luck. I just replaced mine last week.
Use a long, thin phillips screwdriver with a blade 1/4 inch wide and about 6 inches long. There is a hole going upwards at about a 45 degree angle just under the tilt lever on the right side of the steering column. With the switch in run position, slide the screwdriver into the hole and push while slightly rocking the key back and forth and pulling outward. When the pin releases, the cylinder should slip right out.
To install new cylinder, rotate the key till you can depress the pin by hand then slide into the hole. Rotate the key to off and the pin will be engaged.
PS I bought a replacement cylinder for $16 and took it to a lock shop and had it re-keyed to my original keys for an additional $25.
Dialtone
Old 09-25-2002, 04:39 AM
Hey Dialtone thanks for the info. Would I be correct in saying your a telephone guy by trade. I'm a cable and antenna guy myself. I will try this and I'll let you know if I find that damn pushpin.
Old 09-25-2002, 07:29 AM
SplashMan's Avatar
SplashMan SplashMan is offline
SplashMan is starting off with a positive reputation.
Hot to replace key lock cylinder in 1993 Ranger? Outspoken1 Ranger & B-Series 4 12-29-2015 09:13 AM
65 Ford F100 Master Cylinder Jimbo484 1961 - 1966 F-100 & Larger F-Series Trucks 0 12-16-2015 09:51 PM
Removing Manual Door Lock Cylinder 94_Ford_Ranger Ranger & B-Series 1 10-02-2015 10:57 PM
Key won't come out of the cylinder, and re-connecting horn procedure KG4NEL 1968-2013 Full Size Vans 1 08-16-2015 12:50 PM
Slave cylinder push rod? 94 300 1987 - 1996 F150 & Larger F-Series Trucks 1 01-06-2015 06:29 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
