Rear Wiper Blade Doesn't Wipe
Old 06-09-2002, 12:50 AM
Horrortaxi's Avatar
Horrortaxi
Horrortaxi is offline
Post Rear Wiper Blade Doesn't Wipe
The rear wiper blade on my 98 Explorer Sport only contacts the glass on the lower 1/3 to 1/2 of the blade. At first I thought I had a bad wiper blade so I replaced it. Now I've had a close look and realize the thing just doesn't touch the glass. I've searched the boards, the net, and the Haynes manual but haven't found a fix. Anybody have one?
I suspect the fix is to replace the wiper arm so I'll ask in advance if anybody knows what one costs. Thanks.
~Dan
Old 06-09-2002, 11:37 AM
OneShotBandit's Avatar
OneShotBandit
OneShotBandit is offline
I have the same problem on my '98 XLT.
Old 06-10-2002, 07:16 AM
duketter's Avatar
duketter
duketter is offline
Not sure if you already fixed it, but I had the same problem on my 99 Explorer and it is the rear wiper arm. Just replace that and it should work just fine. Not sure what happens but that should fix it.
Old 06-13-2002, 11:52 PM
drifter's Avatar
drifter
drifter is offline
Try taking some W-D 40 to the rivets on the arm where it flexs. Work it back and forth a few times . Sometimes these joints "stiffen up" with dust and dirt and alittle W-D 40 frees them up. This cure worked for both the front and rear wipers on my 98 Explorer XLT. My front ones streaked with new blades and this worked for me, and hope it works for you.
Old 06-14-2002, 08:52 PM
SC98Lariat's Avatar
SC98Lariat
SC98Lariat is offline
Just bend the wiper arm so that it contacts the glass fully. The arm gets sprung after sitting on its rest for awhile. A new arm will do the same thing after a few months.
Old 08-27-2002, 07:06 PM
mgazak's Avatar
mgazak
mgazak is offline
I just noticed this problem on my father's 2000 X while driving it the other day (the wiper when pointing almost straight up would miss all but the very center of its path, wither end of its path was fine). It bugged the hell out of me so I took a look at it. I sprayed some WD-40 on the arm and worked it around. This still didn't work. So I was looking at the blade itself comparing it to mine (98 X) which works great. Besides his being about an inch shorter, there's an extra little piece in the center of the blade frame that prevents it from swinging almost an 180 degree turn. The wiper on mine doesn't have this extra piece so it can move nearly 180 degrees. What's happening, atleast with my father's, is that the wiper itself can not adjust to fit the window completely in that one position that would require it to move the most ( just about the center of the glass). I'm going to try and find a better wiper that's a little longer and has a greater range of movement like mine. I'll keep you posted.
I'm just curious why I never noticed it before.
Old 09-22-2002, 12:15 AM
MileHighRob's Avatar
MileHighRob
MileHighRob is offline
I recently purchased a 2001 Explorer Sport and have the same problem with my back wiper. It's almost as though the arm has been bent since it only touches a small section of the rear glass surface.
I'm wondering if anyone knows how much a new arm costs...
Thanks in advance,
Rob
Old 09-22-2002, 03:54 PM
Horrortaxi's Avatar
Horrortaxi
I fixed this in June by replacing the wiper arm ($30 from Ford). Later I discovered the same problem and fixed it by bending the wiper arm toward the glass until the blade made better contact.
~Dan
Old 09-23-2002, 09:17 AM
duketter's Avatar
duketter
duketter is offline
Also, if you have a 2001 I am thinking you still have a factory warranty so it should be free to replace. Just go take it in and have them change it under your factory warranty!
Old 09-23-2002, 09:23 AM
Horrortaxi's Avatar
Horrortaxi
>better contact.
I should say I discovered the problem on a different vehicle, not on the Explorer.
~Dan
Old 09-25-2002, 10:46 AM
mjs's Avatar
mjs
mjs is offline
Old 09-28-2002, 06:57 PM
MileHighRob
Thanks for the advice! I was assuming this should be covered under the original factory waranty, but not sure. I will take it in as soon as time allows. I know this will drive me insane during the winter months if I have to stop my EX to get out and knock the snow off my rear window.
fixnair
21
05-07-2015 06:53 AM
fixnair
General Automotive Discussion
04-27-2015 10:52 AM
Jesser02EX
03-04-2014 06:31 PM
Big-Red-Lariat
Escape & Escape Hybrid
12-29-2010 09:01 AM
western star
03-02-2008 11:03 PM
Quick Reply: Rear Wiper Blade Doesn't Wipe
