Engine revs upon start-up
When I start my 2004 FX4 F-150, after it has sat for a couple hours, sometimes right after the starter has turned the engine it revs really high for about half a second and then resumes regular rpms. This doesn't happen all the time and not in any particular temperature, and only right after the engine starts. Is this normal? Has anyone else experienced this? Oh yeah, I have a 5.4L Auto.
Thanks
Thanks
on
1 Post
Originally Posted by gmcplus03
mine will idle higher for a few seconds right after startup, then drop to normal idle rpm. my two rangers (01, 03) prior to my 04 f150 fx4 did this as well, was told by my dealer that this is a warm up function for the engine, reguardless of a cold or warm start.
-Matt
I've tried to figure this out beforre and ended up getting many different answers. Some say it's to warm-up/ get oil pressure sooner, some say it's emmisions, and some say it's part of the start-up diagnoses. I've even heard a few I don't remember. It won't happen all the time as it's from the computer and only certain parameters call for it (I can't figure them out though). I wouldn't waste time at the dealer unless it needs to go anyway. Go if it will make you feel better, but it is normal.
