Timing On 85 2.3L
Timing On 85 2.3L
I was wondering what a good ignition timing for the engine would be?
I dont wanna go stock timing because i know thats crap. I dont care about fuel milage, I just want to squeese as much out of my engine as I can with out spending any money.
I got an aftermarket muffler and an air intake if that makes any differance
I don't think I want to do any thing big like that. I just want little tweaks I can do to make a diferance. So far I got my muffler and air intake, and I indexed the spark plugs.
I didn't really look at the distributor to look to see if I could rotate it, But the book I got says something about 'octane rods' to change the timing. Whats the deal with that?
Well, just look inspect it and see if it seems reasonably clean is all. Make sure the spray cleaner you use is for FI vehicles. BTW, all the stuff that you dislodge when using FI/carb cleaner goes down into the engine and some will land on the spark plugs. It can create a conductive coating on the plugs which will defeat you efforts for a few more ponies, therefore it's good to do this right before changing plugs.
BTW, why not reconsider that rear end? Torque multiplication = more "seat of the pants" feel. Ranger rear ends are dime a dozen and if you are fairly handy you can manage it. In my area I could pull one for around $75, maybe more if the wrong yard pulled it for me. Honestly, for the money this will provide you with a pleasing amount of "bang for the buck" provided you do the labor. Note too that I have not suggested having a new ring and pinion installed as that won't be anywhere near as cheap. I'd give the idea a second thought.
cementhead
24
04-01-2013 11:04 PM
