2005 Dodge Ram PowerWagon
I know it's been discussed but now that more details are out, I'm really impressed by this vehicle. One reason I've taken the time to relay this info is the last thread seemed to bash Dodge for bringing back a highly respected nameplate (the PowerWagon). But look at the list of standard features this vehicle has. It is being touted as the ultimate production off road truck ever built (not by Dodge but by journalists). The Detroit News and others are well ahead of the Magazines in relaying this to the public at large, but I'm sure there will be lengthy magazine articles in the next several months.
Here is the standard equipment on the Power Wagon:
- Hemi (I know, that means 99% of you hate the truck already)
- can chose from stick or auto (not sure which is standard equip.), either way you'll find an aggressive 4 low Tcase mated to it.
- electric locking front and rear differentials (toggle switches on the dash)
- 4.56 gear
- electronic disconnecting front sway bar (toggle switch on dash)
- custom Warn Industries 12,000 lb winch
- 33" tires standard on 17x8 rim, 35" fit wheel wells without modification
- custom wheel flares
- Bilstein monotube high pressure gas shock absorbers
The beast stands 80.6" tall and is ready to take on all obstacles. Basically a truck version of the Rubicon Jeep.
Has Ford ever offered anything that caters to the off-roader to this degree? Is Dodge making a mistake catering to some of the extremists?
- 4.56 gear
Fords have always been the best off-road vehicles. I know a guy who has 38 inch tires on his SD with no lift and no wheel well modifications. And I don't hate it because it has a Hemi, I hate it because it's a Dodge, and even if it's the best Dodge has to offer, their components are cheap and won't last.
Very Interesting
IM not impressed with the Hemi in such a Large Vehicle, as Lariot pointed out, Kinda like im very unimpressed with a 5.4 in a super Duty or Excursion..
At any rate, Im Very Impressed with the Electronic Lockers.. Very Nice Features, although I would have preferred to see some sort of ARB setup so you would have an on board air compressor for airing up tires, etc..But with the Air lockers you always have that Dang Hose hanging there waiting to be ripped by some tree limb.
The Electronic Swaybar Disconnect, Im not sure of?
The Sway bar disconnect is a great Idea and greatly improves axel articulation, however Im not sure How this will be done Elctronically as both ends of the swaybar need to match up perfectly to connect them again meaning usualy perfectly flat ground an a good hammer for the manual disconnects, none theless if it works, kudos to them.
I hope it carries over to Gm and Fords offerings, an Upgraded Z-71 or FX4 package with all the hookups would be great..
This can only be good for all who truly wheel their vehicles, as the manufacturers seem to be realizing that a large segment of us really hate driving $40,000 trucks that come off the lot and barely escape wet grass without getting stuck with the wimpy tires and quick wearing useless limited slips.
Terry
Originally Posted by basstardo
I'm callin BS on that one. There is no way he has 38's on a stock SD with no modifications. With a 6" lift you'd be hard pressed to get a set of 38's under there. I do agree that I don't like Dodges though...
Terry
Terry
That statement is not. Lets keep it above the table....
I know it was a slight oversight on your part, I appreciate your support.
Terry
Terry
Originally Posted by MW95F250
How is that possible with a larger engine that's supposed to make more power???
The only engine available is the smaller HEMI.
http://www.rockcrawler.com/features/...powerwagon.asp
