Lincoln/Ford 460
If you are talking only 460 ci, complete factory original engines, then the '77-'78 Ford with 460 ci displacement were the only 460 ci displacement motors to come with 4 bolt mains. The other's were 429 ci displacement (only difference are the crank and pistons).
The heads would be different too. The Lincolns from 1968 to 1971 came with about 75 cc closed combustion chamber heads. In '73 the 460 came with about 86(?) cc open combustion chamber heads. After 1973 they were about 92 cc close combustion chamber heads. All Ford motors came with the latter head, close to it, or the EFI head.
Also the '79 and later 460's came with an externally balanced crank. Also, the Ford 460 was only put in light duty trucks.
Originally Posted by scottie2hottie
which of these heads provides the best CR?
Scott
Scott
Torky
09-24-2013 06:51 PM
64Blubyu
02-20-2008 09:03 PM
f250rangerexplorer
12-05-2004 11:02 PM
