Removing rear drums on 97 F-350
I'm in the process of removing the drums off of the truck and have removed the axle, hub nut and outer bearing on each side. Going by the book, the unit should now slide off but seems to be held on still(kinda spring loaded feeling). I tried prying the drum but something is still attached. Any help would be appreciated.
on
There is probably a lip on the brake drum due to wear from the brake shoes. You will need to "back off" the brake shoes to remove the drum. You can access the star wheel on the slack adjuster thru a slot in the backing plate. You will need to push the adjusting arm away from wheel with a pick or small screw driver to turn the wheel and release the brake shoes.
filthy6
02-06-2014 06:43 PM
gary_b
10-16-2006 07:46 AM
