monster torque 460? - Ford Truck Enthusiasts Forums
monster torque 460?
Old 06-29-2004, 10:19 PM
75f100 75f100 is offline
75f100 is starting off with a positive reputation.
monster torque 460?
how do you build a 460 to make horrindous amouts of torque way down low? i read some where someone had one tha made 550 ftlbs at like 3000ish rpms. it doesn't need to rev over 4000 or so. would like low comp, for cheap gas. what kind of combo would i need? thanks
Old 06-29-2004, 11:18 PM
kermit's Avatar
kermit kermit is offline
kermit is starting off with a positive reputation.
me thinks this needs moved to 460 engine forum.
Old 06-29-2004, 11:53 PM
bassdude bassdude is offline
bassdude is starting off with a positive reputation.
the one i'm putting in my truck is rated 500# at 2800 stock. thats with 10 1/2-1 comp though.
Old 06-30-2004, 12:39 AM
FordPickup460's Avatar
FordPickup460 FordPickup460 is offline
FordPickup460 has a great reputation on FTE.FordPickup460 has a great reputation on FTE.FordPickup460 has a great reputation on FTE.FordPickup460 has a great reputation on FTE.FordPickup460 has a great reputation on FTE.
429 or 460 short block. Factory passenger car conn rods..
C/R from 9.0 to 1 to 9.75 to 1
non ported D0VE-C iron heads
edelbrock performer intake with holley 750 vac secondary carb
Factory dura spark distributor 14 initial and 24 centrifugal for a total of 38 degrees timing.
Comp dual energy cam 206 / 218 @ .050" lift. .497" / .502" lift on a 112 LSA. You can substitute the XE256 H in the comps extreme energy line. Just be carefull of C/R
Factory exhaust manifolds with duals 2 1/4" and H pipe.
160 degree t-stat
Dual snorkel air cleaner.
Factory rail rockers converted to be adjustalbe.
Test done with a 3 x 14" K&N aircleaner
Combo will require 89 to 92 octane pump gas depending on C/R
Chassis dyno numbers are 454 pound feet @ 1,500 RPM and 260 RWHP at 4,500
Ported heads are worth 20 HP as are headers. This is a high torque stump pulling combo.
(This is from www.reincarnation-automotive.com)
Old 06-30-2004, 12:57 AM
Torque1st's Avatar
Torque1st Torque1st is offline
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Moved to proper forum.
Old 06-30-2004, 03:47 PM
Brad Johnson Brad Johnson is offline
Brad Johnson is starting off with a positive reputation.
Try this combo
.030 over stock block
9.5 CR with port matching, bowl blending, and minor porting
750 CFM vac secondary carb
Weiand Stealth intake
Crane Powermax hyd roller 311-2S-12
Long tube headers with primaries in the 1-3/4" to 2" range
Here's the numbers Desktop Dyno comes up with...
RPM Torque / HP
2000 211 / 555
2500 268 / 563
3000 325 / 569
3500 384 / 576
4000 437 / 574
4500 481 / 561
5000 505 / 530
5500 501 / 479
6000 473 / 413
And just to make things interesting, heres the exact same combo applied to 514 cubes (like you get in the Ford Motorsport 514 shortblock).
RPM Torque / HP
2000 236 / 621
2500 297 / 624
3000 356 / 623
3500 414 / 621
4000 463 / 607
4500 494 / 577
5000 499 / 524
5500 475 / 453
6000 428 / 374
Happy Motoring!
Brad
Old 06-30-2004, 04:59 PM
Ooops, I got the Torque / HP labels backwards (wardsback?) in the above thread and it won't let me edit it to correct.
Sorry!
Brad
Old 06-30-2004, 07:21 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
I'm looking to get power like that from my 460..
Anyone know how to ID a cam without tearing the engine apart?
I bought the engine/c6 tranny from a guy taking it out of one sweet 68 stang fastback.
Things I know
1. C8VE Heads, 10.5:1 cr, D1VE block.
2. TCI converter, 2500 stall
3. Edelbrock Torker II intake (single plane)
4. Holley carb, think 750cfm.
5. Nice headers
I 'think' the manifold and converter tell me 2500- up, which sort of matches with the Comp Cams - Ford 429, 460 Xtreme 4x4 X4270H Cam
Sam
Old 07-01-2004, 02:11 PM
77460ford's Avatar
77460ford 77460ford is offline
77460ford is gaining momentum as a positive member of FTE.77460ford is gaining momentum as a positive member of FTE.
I just rolled back from the dyno, '77 4x4 with a 460/C6, 4:11's and 33x12.5's. I made 350HP and 500 ft./lbs of torque at the rear wheels. '77 block 60 over, 10.5 milled TRW's on Eagle SIR rods, DOVE C heads ported and larger valves, COMP valvetrain and 294 solid cam, Edelbrock Performer RPM with 1" spacer and 850 Demon. Stan's Tri-y headers with 2.5" dual exhaust through flowmasters. With the low ratio gear set in the tranny the truck really launches and screams to over 6 grand. Not the most sedate vehicle but what a fun toy.
John.
Old 07-01-2004, 03:03 PM
77460,
As a test agains a known value I ran your setup through Destop Dyno. I cam up with the following crank HP/Torque numbers.
RPM HP / Torque
2000 231 / 606
2500 283 / 595
3000 340 / 595
3500 391 / 587
4000 429 / 563
4500 452 / 527
5000 452 / 475
5500 427 / 408
6000 379 / 331
Corrected using a 22% driveline loss that comes out to theoretical rear wheel max numbers of 352 HP and 473 lb-ft torque. Darned close to what you actually made at the dyno! I'm glad to see that the error was an under estimation of actual torque and not the opposite.
Brad
Old 07-01-2004, 03:08 PM
77460ford's Avatar
Wow! Amazing how far software has come. Big torque is the answer for launching 5200lbs of truck. Thanks for the numbers Brad.
John.
Old 07-01-2004, 05:39 PM
svgearhead svgearhead is offline
svgearhead is starting off with a positive reputation.
Are 9:1 or 9.5:1 compression ratios too high for pulling a trailer (travel trailer)? Assuming high torque/RV cam.
Thanks.
Ben
Old 07-01-2004, 07:31 PM
nice numbers. I'm itching to find out how mine will do. any volunteers to D/D me?
Old 07-02-2004, 10:58 AM
Breeze's Avatar
Breeze Breeze is offline
Breeze is starting off with a positive reputation.
The biggest thing with the D/D's is headflow numbers... the computer will guesstimate close, but with accurate flow numbers, its almost dead on, as for the 9.5:1 pulling a trailer, there should be no problems at all there
Old 07-02-2004, 01:02 PM
bassdude,
post your specs and I'll see what I can do.
Brad
Stock 460 vs Stock 351W for low end torque and hp? eriklane Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 08-06-2015 10:35 PM
Torque Build 460 00Boss 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 01-09-2011 09:31 PM
need mtr.mount info, 391 to 460 conversion whately FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 05-16-2006 10:44 PM
460 cam Blown 331 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 14 02-11-2006 06:30 PM
460 Heads Ron Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 16 02-28-2001 09:41 PM
Tags
262h, 270h, 460, cam, camshaft, comp, curve, ford, id, mc1732, monster, specs, stock, stock460, torque, x4
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
