monster torque 460? - Page 3 - Ford Truck Enthusiasts Forums
monster torque 460?
  #31
Old 07-21-2014, 02:50 PM
wyoming4x4's Avatar
wyoming4x4 wyoming4x4 is offline
wyoming4x4 is gaining momentum as a positive member of FTE.wyoming4x4 is gaining momentum as a positive member of FTE.
Torque 460
Quote:
Originally Posted by sdetweil View Post
I'm looking to get power like that from my 460..
Anyone know how to ID a cam without tearing the engine apart?
I bought the engine/c6 tranny from a guy taking it out of one sweet 68 stang fastback.
Things I know
1. C8VE Heads, 10.5:1 cr, D1VE block.
2. TCI converter, 2500 stall
3. Edelbrock Torker II intake (single plane)
4. Holley carb, think 750cfm.
5. Nice headers
I 'think' the manifold and converter tell me 2500- up, which sort of matches with the Comp Cams - Ford 429, 460 Xtreme 4x4 X4270H Cam
Sam
get rid of the Hyd cam and step into a solid cam around 272 duration and around .540 lift. 750 with 1 to 1 linkage and get some air in that engine. 2500 stall wrong converter for low end torque! Hughes xtm converters are better for low end. Tic converters had lots of problems$$$$$
  #32
Old 07-21-2014, 02:55 PM
wyoming4x4's Avatar
Torque 460
Things I know
5. Nice headers
Sam
Torque Build 460 00Boss 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 01-09-2011 08:31 PM
F250 460 Rv Cam spec's crosshairs1972 General Automotive Discussion 3 03-26-2008 01:44 PM
hp torque specs for '89 460 rusty brown ford New Member Introductions 1 09-08-2007 07:12 PM
460 cam Blown 331 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 14 02-11-2006 05:30 PM
460 Heads Ron Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 16 02-28-2001 08:41 PM
Tags
262h, 270h, 460, cam, camshaft, comp, curve, ford, id, mc1732, monster, specs, stock, stock460, torque, x4
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
