monster torque 460? - Page 2 - Ford Truck Enthusiasts Forums
monster torque 460?
Old 07-03-2004, 12:21 AM
bassdude bassdude is offline
bassdude is starting off with a positive reputation.
Thanks Brad.
i have a 71 460 bored .020 over. stock dove-c heads. kept the 10.5-1 compression. the cam is a EPWI MC1732. the specs are, adv dur:260 int. 270 exh. .050 dur:204 int. 214 exh. valve lift:.479 int. .504 exh. i have a wieand stealth with a edelbrock 750. L&L 3/4 length headers with inch and three quarter tubes. i've also got a C-6 and 205 t-case. anything else you need?
Old 07-05-2004, 10:27 AM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
Quote:
Originally Posted by sdetweil
I'm looking to get power like that from my 460..
Anyone know how to ID a cam without tearing the engine apart?
yanked the cam, its labeled 280H.
Sam
Old 07-05-2004, 04:18 PM
Brad Johnson Brad Johnson is offline
Brad Johnson is starting off with a positive reputation.
bassdude,
I couldn't find valve open/close specs on your cam but it looks like EPWI probably uses Comp Cams pieces with their name on them, so I subbed in the Comp Cams X256H numbers (the specs closest to what you listed). For those who think it takes radical cams to make good numbers, you should pay close attention to the torque curve this mild cam produces.
RPM HP / Torque
2000 208 / 546
2500 262 / 549
3000 314 / 550
3500 364 / 547
4000 408 / 535
4500 435 / 507
5000 439 / 461
5500 417 / 398
Look at the big, fat torque curve. That's 500+ lb-ft torque on tap from just off idle all the way up to 4500 rpm. Now THAT'S useful torque - Very nice!
I played with things to see if I could tweak the numbers a bit, but it looks like your combo is pretty solid.
Brad
Old 07-05-2004, 06:11 PM
WOW!!! Thanks brad i'm really glad to see those kind of numbers. i let the machinist i used pick the cam for me. i guess it pays to deal with poeple who know what they are doing. thanks for your time and effort Brad. man, i really can't wait to get this in my truck!
Old 07-05-2004, 06:42 PM
75f100 75f100 is offline
75f100 is starting off with a positive reputation.
Quote:
Originally Posted by 77460ford
I just rolled back from the dyno, I made 350HP and 500 ft./lbs of torque at the rear wheels.
John.
were the rpm's the same as the chart Brad posted? those are some low rpm's on that torque figure for that big a cam.
Old 07-05-2004, 07:37 PM
77460ford's Avatar
77460ford 77460ford is offline
77460ford is gaining momentum as a positive member of FTE.77460ford is gaining momentum as a positive member of FTE.
The chart didn't start on the last pull until 3750rpm but showed the following:
RPM HP Torque
3750 324 453.8
4000 330.5 434.0
4250 329.0 406.5
4500 321.9 375.7
4750 316.8 350.3
5000 322.8 339.1
5250 330.6 330.7
5500 338.5 323.2
5750 345.8 315.9
6000 343.1 300.3
6250 344.3 289.3
6500 334.8 270.5
We spent over three hours strapped on the dyno with jet changes and timing adjustments and tweaking different little things. I'm happy with the way the motor works and the low ratio gear set in the C6 really help with a good launch. I hope to get to Grand Bend on a test and tune night and try the 1/4 just out of curiosity.
John.
Old 07-06-2004, 01:06 AM
There Goes The Neighborhood's Avatar
There Goes The Neighborhood There Goes The Neighborhood is offline
There Goes The Neighborhood is starting off with a positive reputation.
RPM HP/TQ
2000 211 554
2500 274 575
3000 333 582
3500 393 589
4000 451 592
4500 502 585
5000 537 564
5500 549 524
6000 531 464
6500 510 412
Actual flwhl numbers for CID473's 473. Lots of ***** through the mid range, plenty at 6000, and a whole lotta fun.
Old 07-06-2004, 04:51 AM
can you D/D gurus build me a combo that makes the most torque and hp without reving over 3000rpm's. its for a boat project i have. thanks.
Old 07-06-2004, 10:18 AM
See bassdude's combo that I DD's earlier in this thread. It's looks like a pretty solid low-end torque setup.
Old 10-03-2004, 10:12 AM
vogey vogey is offline
vogey is starting off with a positive reputation.
can anyone run a dd for me i can't seem to decide on what cam to use.. im running a 76 460 9.5-1 d3ve heads mild port (clean up exuast) stock valves performer rpm intake, headers with 1.75'' primarys and 2.5'' dual exuast im stuck on either a 000096 lunati cam or the extreme energy 4x4 cams.. girnd FF X4 262H-11 or the FF X4 270H-11 or the cam they just ran up there Comp Cams X256H any thing else you need?
Old 02-04-2006, 04:59 PM
jay54f100's Avatar
jay54f100 jay54f100 is offline
jay54f100 is starting off with a positive reputation.
I have a 85 4x4 460 and want to get the most torq out of it. I want to put a holly 750 dubble pumper, Elelbrock air-gap manifold, mild head work with some ss valves and rocker arms parts, forged pistons, bored .030 over, crank .010 under and a roller cam. i need some help picking out a good a good cam.
Old 02-06-2006, 11:41 AM
Most of the current crop of split duration cams in the 255-265 range will probably fill the bill nicely. Great power without sacrificing any low-RPM response or daily driveability.
Ditch the double-pumper. Get a good vac secondary 750. Easier to tune.
Brad
  #28
Old 01-29-2014, 04:32 PM
lineboy lineboy is offline
lineboy is starting off with a positive reputation.
I too am building a street 460, looking to make a lot of torque. So far I've ported,polished, bowl blended a set of d3ve heads and they are at the shop getting new stainless 2.19 intakes and 1.76 exhaust valves. Going to do the head work to figure out what the best pistons,cam, and cr. To use to get the most low end torque
  #29
Old 01-30-2014, 02:03 PM
jay54f100's Avatar
Let me know what you come up with got another engine to build.
  #30
Old 03-23-2014, 05:59 PM
jamusfam jamusfam is offline
jamusfam is starting off with a positive reputation.
Just curious a stock 71 Lincoln 460 with holly carb and c6 this is going in my 75 f250.
Torque Build 460 00Boss 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 01-09-2011 08:31 PM
F250 460 Rv Cam spec's crosshairs1972 General Automotive Discussion 3 03-26-2008 01:44 PM
hp torque specs for '89 460 rusty brown ford New Member Introductions 1 09-08-2007 07:12 PM
460 cam Blown 331 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 14 02-11-2006 05:30 PM
460 Heads Ron Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 16 02-28-2001 08:41 PM
Tags
262h, 270h, 460, cam, camshaft, comp, curve, ford, id, mc1732, monster, specs, stock, stock460, torque, x4
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
