1998 Explorer XLT Keypad Code - Ford Truck Enthusiasts Forums
Old 06-18-2002, 08:36 PM
johndoro johndoro is offline
johndoro is starting off with a positive reputation.
Post 1998 Explorer XLT Keypad Code
I have recently purchased a 1998 Ford Explorer XLT. The previous owner did not know the door keypad code, and it did not come with an owners manual or any documentation. Is there a way I can find out the code for the drivers door keypad without taking it to a dealership?
Thanks!
Old 06-18-2002, 10:12 PM
nitro94's Avatar
nitro94 nitro94 is offline
nitro94 is starting off with a positive reputation.
You will find the code on a piece of tape on the keyless entry module. Sorry I can't tell you where to find it without a component locater which is not at home where I am now. You will probably have to remove it and look on the back side to find it.
Old 06-18-2002, 10:34 PM
Of course the keyless entry module was also missing when I purchased the vehicle... just trying to save myself a few bucks at the dealership...
Any other responses from any one else are always welcome!
Thanks!
Old 06-18-2002, 10:54 PM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
to get the code you need to go to drivers side back where the jack is kept,you'll find the module(raps)the code is on the back of this module.
if you don't have the keyless entry modules and want to purchase them from ford you will have to go through a procedure to program them.
We can help you with that ,if needed.
Rich
Old 06-21-2002, 01:43 AM
drifter drifter is offline
drifter is starting off with a positive reputation.
I bought a couple of keyless entry modules on EBay for my 98 Explorer XLT cheaper than at the Ford dealer. They are simple to reprogram and some sellers on EBay include the directions with them. Hope this helps.
Old 10-10-2002, 01:45 AM
Dreafull Dreafull is offline
Dreafull is starting off with a positive reputation.
tryn to figure if there is a way to reprogram with my own keypad code instead of the one suplied. truck was bought used and id rather have own code.
any help would be aprech. dreadfull2day(No Email Addresses In Posts!)
thanks in advance.
(1997 explorer)
Old 10-10-2002, 08:44 PM
mgazak's Avatar
mgazak mgazak is offline
mgazak is starting off with a positive reputation.
>thanks in advance.
>(1997 explorer)
You can program a personal code for yourself, but the one from the factory stays no matter what. Sorry...
Old 10-10-2002, 10:11 PM
bluesoftail bluesoftail is offline
bluesoftail is starting off with a positive reputation.
Old 01-25-2012, 10:23 AM
somstevens somstevens is offline
somstevens is starting off with a positive reputation.
I have recently purchased a 98 Explorer XLT. I found the keypad code but the sticker is wrinkled and I cannot see all of the letters. Is there another location where I can find it? Also when I get the code what are the steps I need to take to add my own personal code?
Old 01-25-2012, 01:13 PM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
If you have the owner's manual for your Explorer, it may still have the little credit card sized card with the keyless code printed on it. If no card, then maybe a previous owner wrote the code in the manual. Check inside the front and rear covers, if not there, then open to the section on the remote keyless entry and see if it's written on those pages. Those pages will also explain how to program a personalized code once you know the factory code.
If none of that works, you may need to find someone with a professional scan tool who can access the module and read out the factory code.
-Rod
Adding keypad to drivers door? johnzenobia 2009 - 2014 F150 9 04-27-2015 12:16 PM
99 Explorer with keypad on door ssparay Explorer, Sport Trac, Mountaineer & Aviator 2 09-26-2012 07:28 AM
How do I reset the ext. keypad tkiner 2009 - 2014 F150 4 01-11-2010 02:27 PM
Explorer driver's door numbered keypad Ford 4 Life Explorer, Sport Trac, Mountaineer & Aviator 6 03-12-2002 06:05 PM
Expedition Keypad Door Handle pstapler 1997-2006 Expedition & Navigator 4 03-01-2001 09:58 PM
Tags
1997, 1998, 2002, 50l, 98, code, door, drive, ebay, entry, explorer, ford, front, keyless, keypad, location, shaft, sport, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
