Horn Problems on a '98 Ford Explorer XLT - Ford Truck Enthusiasts Forums
Old 10-08-2002, 04:09 PM
California Gas California Gas is offline
California Gas is starting off with a positive reputation.
Hope someone can help!
I recently went on a vacation for 3 weeks and my Explorer was not used....before I left for vacation my horn was loud and very rich....since I have come back it only emits a whimper and is very weak.
I have 2 questions, where is the horn on a '98 Ford Explorer XLT? and does anyone know whats wrong, or have any idea how to fix it?
Thanks in advance!
Old 10-08-2002, 05:16 PM
Mil1ion Mil1ion is offline
Mil1ion is starting off with a positive reputation.
I assume you have cruise control?
If so,Ford runs the horn through a relay under the dash.(at least That where they used to put it)
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old 10-08-2002, 09:14 PM
CobraXP's Avatar
CobraXP CobraXP is offline
CobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to beholdCobraXP is a splendid one to behold
The horn is located under the battery. You access it from pulling down the front bottom part of the fenderwell from underneath. Your horn is actually 2 horns. They are notorious for grounding themselves out. Yours may only have one of the horns out.
When you feel in there, you will feel the power wire to one, and a jumper running to the second. My guess is the jumper has either broke or come off. If the horn grounds itself out, you will lose both the horn and your cruise. They are run through the same circuit in the main Distribution Block under the hood next to the back of the passenger side fenderwell.
Hope this helps...
Old 10-11-2002, 05:50 PM
Thanks for the info! I shall investigate this weekend!
Old 10-11-2002, 07:42 PM
topo4u2 topo4u2 is offline
topo4u2 is starting off with a positive reputation.
Horn Question Green72F250 1967 - 1972 F-100 & Larger F-Series Trucks 6 06-26-2014 02:40 PM
horn won't work F350moneypit 1973 - 1979 F-100 & Larger F-Series Trucks 19 02-04-2013 01:46 AM
98 EXPLORER EDDIE BAUER RADIO AND HORN AND KEYFOB NO LONGER WORKING. loleuiha Explorer, Sport Trac, Mountaineer & Aviator 2 03-09-2011 12:56 AM
Horn Horn Horn---very weak GormGorm 1987 - 1996 F150 & Larger F-Series Trucks 2 04-04-2010 11:21 PM
98 Explorer horn oskie Explorer, Sport Trac, Mountaineer & Aviator 4 01-27-2006 12:38 AM
Tags
2001, 95, 98, 99, cruise, ecplorer, explorer, fix, ford, horn, mountaineer, problems, sounds, weak, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
