Spark plug wire clips - Ford Truck Enthusiasts Forums
Old 09-19-2002, 11:14 AM
SA Struck SA Struck is offline
SA Struck is starting off with a positive reputation.
Post Spark plug wire clips
I'm changing out the plug wires on my '99 Mountaineer (V8), and I'm having a heck of a time unclipping the wires. Is there any easy way to do this? I can't even get to the clips on the #4 wire. What a pain.
Old 10-11-2002, 03:19 PM
missviv2's Avatar
missviv2 missviv2 is offline
missviv2 is starting off with a positive reputation.
I had that same problem and then I looked inside my front wheel wells. There is a plastic cover on each side of the vehicle that protects the engine from the stuff that you run over. This cover is held on with plastic clips, like those that attach your door trim to the door. Once you pull on them (hard if you have to, I haven't broken or ripped anything yet) and take off the cover, the #3 and #4 plugs are right in front of you and so much easier to reach. This is the same on the driver's side for plugs 5, 6, 7, and 8. I hope this helps you.
Vivian
Old 10-11-2002, 07:42 PM
topo4u2 topo4u2 is offline
topo4u2 is starting off with a positive reputation.
I have a hint for plug installation....put an old rubber plug boot on the new spark plug. It will make the job a lot easier! It will be so much better to start the threads.
Mike: 1995 Explorer XLT,4.0 litre, 3.73 non-slip.
Old 10-12-2002, 02:44 AM
97 awd xlt blue 97 awd xlt blue is offline
97 awd xlt blue is starting off with a positive reputation.
Broken coil-on-plug wire clip--How to fix? deerhuntre 2004 - 2008 F150 12 10-06-2015 06:36 PM
question about a wire 1986stepsidef150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 07-27-2014 11:28 PM
Factory Electronic Clock Wiring... granny_rocket 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 04-26-2013 07:57 PM
Stereo install on my 1997 Ranger with premium sound dae06 Ranger & B-Series 0 12-29-2011 10:56 PM
Wiring help rbrondan Electrical Systems/Wiring 1 01-10-2005 12:54 PM
Tags
352, 50, attach, clip, clips, duty, fe, ford, heavy, ignition, open, plug, ranger, spark, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
