460 Moroso oil pan?
since you did say I assume you are talking about 78 or later bronco, if so they will work for that swap, as they are the same as the F150 for the same years, if you are talking about the early broncos they are a different animal all together, and I would have to say that is a trial, and error situation although someone on here probably has done it, and could answer that one better. but I have seen a 78 bronco 460 with one of those pans, and it worked fine.
hasteranger
04-29-2016 03:28 PM
Kyle Campbell
04-13-2016 08:56 PM
Skagit
02-28-2004 03:59 PM
