Change in Recommended Oil Weight for 4.0L SHOC? - Ford Truck Enthusiasts Forums
Old 06-28-2004, 04:58 PM
LV Dan LV Dan is offline
LV Dan is starting off with a positive reputation.
This question hit my mind after a discussion in another thread.
My owners manual for a '99 4.0 SHOC (Explorer XLT 4wd) recommends 5w30 engine oil for all seasons.
For those of you with 2000 or newer 4.0 SHOC vehicles, does Ford still recommend 5w30 oil for all seasons including hot temperatures?
Old 06-28-2004, 11:56 PM
Rockledge's Avatar
Rockledge Rockledge is online now
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
The answer to your question is yes, Ford still recommends 5W-30 for the new SOHC engines. But that doesn't mean shouldn't use a 10W-30 in your '99 during the hotter summer months, and in fact, that's probably what I would do if I lived where you do.
Old 07-21-2004, 04:30 PM
94tbirdman's Avatar
94tbirdman 94tbirdman is offline
94tbirdman is starting off with a positive reputation.
I always use 10W-30 synthetic, either Mobil One or Quaker State, in my '01 with the 4.0L SOHC V6. No problems.
Old 09-03-2012, 06:22 PM
LRunestad LRunestad is offline
LRunestad is starting off with a positive reputation.
Quote:
I have a 2005 Explorer with the 4.0L SOHC V6. I just changed the oil and used Mobil 1 10W30. Have the engine tolerances tightened since 2001 and should I be concerned?
Old 11-20-2012, 05:38 PM
Ramble on Ramble on is offline
Ramble on is starting off with a positive reputation.
Quote:
No. The change to 5w oil in all engines was driven by the need optimize fuel economy. Everything that can be reasonably changed to improve fuel economy is being done, driven by regulation and market demands. Some items such as electric power steering ilo engine driven hydraulic make a noticeable difference, some such as going from 10w to 5w oil is a minor change. Expect to see 0w recommendations.
You are good to go for as many miles as you wish to keep the vehicle.
Oil Use conchstew Explorer, Sport Trac, Mountaineer & Aviator 3 03-28-2015 08:21 AM
Timing Chain Concerns and Questions 4.0 SHOC Sport Trac gaknak Explorer, Sport Trac, Mountaineer & Aviator 0 02-11-2015 05:31 PM
Anyone herd of this LIFT from NTW? Suspension special or cage offroad? Madmaxz 1999 to 2016 Super Duty 16 06-13-2008 08:46 PM
Need a Fuel Pressure Regulator LV Dan Explorer, Sport Trac, Mountaineer & Aviator 1 09-26-2005 09:04 PM
Opinions on proper weight oil for Ranger? GWIGG Oil & Lubrication 15 07-29-2005 01:44 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
2000, 2004, 30l, 40, 40l, change, eng, explorer, ford, oil, ranger, reccomended, recommended, trucks, viscosity, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
