Tire size on 1999 F-250 V10 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-28-2004, 03:10 PM
Daren12 Daren12 is offline
Daren12 is starting off with a positive reputation.
About to purchase a new set of tires for my 1999 F-250. It has 235/85 16 on it now. It says on the door the wheels are 16x7. A friend of mine has a 2001 f-250 Diesel and it came with 265/75 16. Do both of these have the same 7 inch wheel. Inside the door on his also it says 16x7 inch wheel size also. He put 285's on his, Can I put 285's on mine also? Thanks!
Daren
Old 06-28-2004, 05:17 PM
etcetera etcetera is offline
etcetera is starting off with a positive reputation.
Same size wheel. I've got 315/75R16's on 16x7's. I think that's about the upper end size wise. 315's rub ever so slightly on the leaf springs when maxed out on a tight right turn. I've got 3.5" hangers in front.
I think my truck came stock with 265 75 R 16's.
Eric
Old 06-28-2004, 07:48 PM
DS02F250 DS02F250 is offline
DS02F250 is starting off with a positive reputation.
Daren,
Welcome to FTE! 265/75's thru and including 305/75's will fit on 16X7" rims. And as has been mentioned above, 315's will fit the 16X7" rim, but will rub as noted.
DS
Old 06-28-2004, 11:31 PM
Yota-eater Yota-eater is offline
Yota-eater is starting off with a positive reputation.
I'm running the 315 75 R16 on my 00' F-250 with stock front suspension and stock wheels. Like it was mentioned, at full lock either way I have a little rub on the leaf springs but not much. The size is nice and fills the wells nicely.
Geoff
Old 06-28-2004, 11:53 PM
99PSDCREW 99PSDCREW is offline
99PSDCREW is starting off with a positive reputation.
Daren,
I just put a set of 285 ProComps on and all is very well. No rubbing, plus the tires don't look too big for the stock wheels.
99PSDCREW
Tire Sizes for 1977 F250 Tim Edwards 1973 - 1979 F-100 & Larger F-Series Trucks 4 09-07-2016 07:41 AM
Limits of stock rims Swagtastic Excursion - King of SUVs 12 12-20-2011 07:52 AM
16.5 inch rims on my 1981 F250 supercab? riparian 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 10-15-2009 08:55 PM
Tire Size Increase/Rim Width av226 1999 - 2003 7.3L Power Stroke Diesel 9 09-05-2008 06:51 PM
Tire Size?? caddylt1 1999 to 2016 Super Duty 19 12-09-2007 11:21 PM
Tags
16x7, 1999, 250, 31575r16, 6, f250, fit, fits, ford, lt31575r16, options, rim, size, tire, tires, v10, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
