99 Ford explorer modulator valve
I own a '99 Ford Explorer and have had a problem with loosing transmission fluid. The only problem is it doesn't leak out..... I called around and found someone who told me it could be a modulator valve that is busted and the fluid gets sucked into my engine. Two questions...... How will this affect the engine (problems in the future?) and how extensive are the repairs(i.e. is this a do-it-yourself or shop job)?
I'm not real familiar with the newer Explorers, but I was of the impression that the '95 and up transmissions were all electronically controlled. Thus there would not be any vacuum modulator. Vacuum modulators were only present on the '91-'94 Explorers with the A4LD transmission.
To add my own speculation, is it getting into the transfer case (if 4WD)?
Into the coolant through the "ATF cooling line" in the radiator?
FordTruckfan89
08-28-2016 03:52 PM
kjester
15
03-17-2011 02:31 PM
MuddyGrimes
09-19-2004 10:07 AM
BrianJ77
08-15-2003 09:45 PM
Legend
05-23-2002 01:51 PM
