2002 explorer xlt radio removal???? - Ford Truck Enthusiasts Forums
Old 10-03-2002, 05:32 PM
rwatson119 rwatson119 is offline
rwatson119 is starting off with a positive reputation.
how do i remove to panel around teh radio on a 2002 ford explorer 4door xlt. it has manual air conditior. OR can you please help me remove the factory radio on my truck
THANKS
Old 10-06-2002, 03:58 PM
Islander69 Islander69 is offline
Islander69 is starting off with a positive reputation.
I removed my radio two weeks ago. The center console should pop out. There are 6 clamps that is holding the console in. Start with the top 2 and use a wide and long flat head screw driver and a cloth to protect your dash. Once you have the top 2 popped out, get a flash light and look for the middle two clamps, use the screw driver to pry it loose from the inside. Once you have that its all down hill from there. Note: you don't have to pop out your ac ***** or your air vents.
Terry
Old 10-25-2002, 03:25 PM
edlmann edlmann is offline
edlmann is starting off with a positive reputation.
>THANKS
This may help:
http://www.pro-fit-intl.com/Adobe/FO-71-02.pdf
Old 10-25-2002, 04:25 PM
reberhardt reberhardt is offline
reberhardt is starting off with a positive reputation.
Can I Install a Newer Radio in an Older Vehicle? allanhilliard 1997-2006 Expedition & Navigator 2 01-13-2017 11:59 PM
2003 Explorer XLT 4x4 Dash Removal? davidtabercrombie Explorer, Sport Trac, Mountaineer & Aviator 3 06-01-2016 10:14 PM
2002 explorer front differential diagram svujke Explorer, Sport Trac, Mountaineer & Aviator 1 05-09-2016 09:51 PM
No Dash or Center console lights on 2002 Explorer XLT. lindazman Explorer, Sport Trac, Mountaineer & Aviator 6 12-07-2015 06:35 PM
2002 explorer fuel filter location volks Explorer, Sport Trac, Mountaineer & Aviator 1 12-10-2003 10:33 AM
Tags
02, explorer, radio, remove, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
