resistor ballast on ignition switch - Ford Truck Enthusiasts Forums
Old 06-27-2004, 03:44 PM
ranchero73 ranchero73 is offline
ranchero73 is starting off with a positive reputation.
Hey guys!
I'm converting a 73' ignition to the duraspark electronic ignition. Some of you guys help me on this, what I need to know is where does the resistor ballast exist on the harness for the ignition switch (i need to splice my wire between that and the ballast) for my lead.
thanks!
Old 06-27-2004, 10:38 PM
grclark351 grclark351 is offline
grclark351 is gaining momentum as a positive member of FTE.
the duraspark uses two wires for power, one for cranking voltage and one for running voltage. red and white, i can't remember which is which but i think the red is crank? the cranking voltage is not resisted but the run voltage is lower from what i remember. the ballast is the wire itself, it's a resistor wire, if i remember correctly it was dark green and had writing printed on it identifying it as such. real small writing.
429TJ + ignitor by pertronix + accel super coil FORDF250HDXLT Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 11-22-2015 08:53 AM
Help choosing the right ballast resistor?? ApocalypseBob 1973 - 1979 F-100 & Larger F-Series Trucks 3 08-24-2015 03:56 AM
Pink wire? 19711969 1967 - 1972 F-100 & Larger F-Series Trucks 5 07-28-2015 09:39 PM
Ballast Resistor Part Number jack orchard Ford Inline Six, 200, 250, 4.9L / 300 4 04-22-2015 03:34 PM
Ignition coil problems ved0303 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-02-2015 11:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
