1998 Explorer radio problem - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 09-03-2002, 09:34 PM
duharris duharris is offline
duharris is starting off with a positive reputation.
Post 1998 Explorer radio problem
Find a fix at the following web site:
www.shareamemory.com/radio
Regards,
D Harrison
  #32
Old 09-11-2002, 01:48 PM
Atfishs4t Atfishs4t is offline
Atfishs4t is starting off with a positive reputation.
Hello! I am new here and I have the same problem with our 1998 Explorer. I have read through all of the fixes (and called the dealer: $400.00!!!) and I am hoping this will work: Does anyone know if the CD Player from a 1999 Explorer will work in a 1998 Explorer?? The faceplate is exactly the same, but I am worried about the wire harness in the back. Will the plugs match? I went to a few car audio places and they want to see the car AND the CD player. I am trying to fix this as a present for my husband's birthday and I have to steal his car while he's at work. (Therefore, I don't ever have the car to show them-only the CD player.)
Also, is anyone having the same problem with the 1999 models?? I don't want to fix this one and then have to fix another one.
ANY replies are appreciated! I am clueless about this.
Thanks,
~Anne
  #33
Old 09-30-2002, 09:02 PM
rcastle57 rcastle57 is offline
rcastle57 is starting off with a positive reputation.
My 98 XLT did this the other nite, the display started to blink on and off at random. I got really frusterated then I moved the instrument cluster dimmer switch to full bright then dim and it fixed it. My guess is the switch had been in one position too long and may have caused a bad spot in the reostat dimmer switch.
  #34
Old 10-08-2002, 11:19 PM
1998 and 1999 CD players should be swappable. I have put together a web site to help those with the radio display going out and I have tested 1998, 1999, and 2000 radios in my own 2000 Explorer. Take a look at www.shareamemory.com/radio and let me know if I can assist you in anyway.
Regards,
D Harrison
  #35
Old 10-13-2002, 07:29 AM
Opera House Works Opera House Works is offline
Opera House Works is starting off with a positive reputation.
  #36
Old 10-13-2002, 11:33 PM
Ford_Girly Ford_Girly is offline
Ford_Girly is starting off with a positive reputation.
This seems to be a much better solution than my husband's - which was to test drive an Explorer and pull out the radio and swap it with my lightless one. Much better - and less chance of jail time as well.
Anyhow, my lights on my radio on my '99 Explorer went out for good about 3 months ago - and I'm glad I didn't bite the bullet and have the dealer fix the radio at a $200 charge.
We'll be pulling out the radio, following the directions and hopefully be up & running again sometime this week.
Thanks to whomever posted the link with the fix ... it's much appreciated!
  #37
Old 10-25-2002, 10:53 PM
itgeek itgeek is offline
itgeek is starting off with a positive reputation.
I just bought a used 1998 Explorer Sport with this problem. I have to say it makes me feel better that it's not just me.
Thanks to all of you that have posted fixes for this. I am very appreciative. So far, I haven't been able to get my radio to come out. I'm not sure if I'm not pulling hard enough or what.
Thanks again,
Melanie
  #38
Old 10-26-2002, 07:26 PM
ford_fanatic ford_fanatic is offline
ford_fanatic is starting off with a positive reputation.
Anybody wanna sell their headunit?
  #39
Old 02-14-2003, 11:52 PM
radiorepair radiorepair is offline
radiorepair is starting off with a positive reputation.
Edited by moderator because of business advertisement
  #40
Old 02-16-2003, 10:59 AM
How did I get to be starter of this thread? Never even posted here. Sure, I have a post here but it is from another thread and the body of the post never came with the title.
I do think the $19.95 charge for information is a little steep. Can only hope he gets a job so he doesn't have to be pimping himself on the boards. Maybe we should all start charging for advice.
  #41
Old 02-17-2003, 04:47 PM
wideopen wideopen is offline
wideopen is starting off with a positive reputation.
I'm having the same Problem with my wifes 99' ..I read earlier in the post "for $185. you can have it repaired" Why the factory radios that they put in these Explorers are not that special .. before I'd spend that much to have one repaired I'd go buy a new unit from walmart or even a local stereo shop and have a whole lot better head unit for less.. Just my two cents..
  #42
Old 04-01-2003, 09:04 AM
Amanda Amanda is offline
Amanda is starting off with a positive reputation.
If you like the way the radio is integrated into the vehicle with radio controls on the steering wheel and rear seat controls, I don't know of an aftermarket radio that will replace the Ford radio. It's actually pretty easy to fix with a little soldering experience (or even without...the web site www.shareamemory.com/radio gives soldering tips and techniques for the beginning solderer).
  #43
Old 04-05-2003, 09:11 PM
cfors cfors is offline
cfors is starting off with a positive reputation.
I have a '98 Mountaineer with the intermittent radio panel going on and off. I haven't dissassembled the radio yet, but I will. I'm sure that there is a loose connection inside the thing somewhere and it can't be too difficult to find. I'm sure not going to pay $19.95 for a repair manual on the Internet. It defeats the whole purpose of a user-to-user enthusiast forum.
  #44
Old 04-21-2003, 03:47 PM
adam6 adam6 is offline
adam6 is starting off with a positive reputation.
Once you get the radio out. Remove the two small screws on either side of the plastic face plate. Remove the face.(you have to pull back the small plastic clips) There is a plug that attaches the face to the head unit. You must (carefully) remove to detach the face from the unit. On the back of the face there is several small phillips screws that need to be removed. The circuit board should come out fairly easily. Where the display attaches to this board the solder points are probably broken. Solder these and you should be good to go. Ford radios are notorious for this and 90% of the time this is the problem. If not it is probably a power supply which is more difficult and expensive to fix.
  #45
Old 05-06-2003, 06:39 PM
dansbrother dansbrother is offline
dansbrother is starting off with a positive reputation.
Take it out and plug it back in!!!
Before you go through the hassle of paying the guy 20 bucks to teach you how to solder (I hadn't done that), try what I did, since I didn't find any burned up solder joints.
I removed the radio. I took off the face of the unit, and then removed the pcb for the controls and display. Since I didn't find any bad solder joints by plain sight, I decided to try the whole take it apart and put it back together trick.
Well, it worked. Maybe it was a loose connection. Maybe the connectors use crappy material and they corroded. I don't know, but it worked, and I didn't blow $20 for access to a web site, or $185 to have a stereo shop fix it.
Mike
Will RDS CD player from Explorer work in my Ranger? 1998Ranger25L153CID Ranger & B-Series 7 08-03-2016 09:37 AM
No display on radio sdswan Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 8 12-22-2015 12:59 AM
bolt pattern speedracer54729 Ranger & B-Series 2 03-01-2015 11:56 PM
1998 explorer fuel pump assembly r&r 2000+1998 Explorer, Sport Trac, Mountaineer & Aviator 1 02-15-2014 12:46 AM
will a 2001 ranger transmission fit in an 198 explorer eric_engler Explorer, Sport Trac, Mountaineer & Aviator 0 01-04-2014 03:38 PM
Tags
1998, 1999, 2083813831forumsshowthreadphps953f262d7deded414020 433519f151aethreadid39115, 2083813831forumsshowthreadphps953f262d7deded414020 433519f151aethreadid39115radio, dial, display, explorer, explorerradio, f150, f87f18c868ad, fix, ford, mach, problem, radio
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
