1998 Explorer radio problem - Page 2 - Ford Truck Enthusiasts Forums
Old 02-08-2002, 01:24 PM
tercer tercer is offline
tercer is starting off with a positive reputation.
take out the radioand remove faceplate then reinstall plate back onto radio.this must have made the connections tighter as mine has stopped doing this, try it ,it works,rich
Old 02-13-2002, 02:00 PM
rainsinger rainsinger is offline
rainsinger is starting off with a positive reputation.
Post 1998 Explorer radio problem
>looks like someone had the hick-ups!
blushing... newbie here, sorry...
Old 02-13-2002, 03:43 PM
96explorereddieb's Avatar
96explorereddieb 96explorereddieb is offline
96explorereddieb is starting off with a positive reputation.
[updated:LAST EDITED ON 13-Feb-02 AT 03:45 PM (EST)]Check this thread out... Someone found a fix to this problem.
[link:208.38.138.31/forums/showthread.php?s=953f262d7deded414020433519f151ae& threadid=39115|Radio Fix]
Old 06-24-2002, 03:24 PM
wmblanken wmblanken is offline
wmblanken is starting off with a positive reputation.
[updated:LAST EDITED ON 24-Jun-02 AT 03:25 PM (EST)]Here is the fix I used and have had no problems since.
Go to www.shareamemory.com/radio
Old 06-26-2002, 07:54 AM
winfordr's Avatar
winfordr winfordr is offline
winfordr is starting off with a positive reputation.
I, too, am another satisfied "customer". I went to the above referenced site, printed off all 10 or so pages.
I have had the same problem with my 98 Explorere (intermittent display only). For the past 2 days, it has not worked at all.
So, using the instructions, I repaired the unit, and now it works perfectly!
I added a little extra -- I used a stainless tooth brush and burnished the connections on the power supply board before soldering.
Then, I soldered every connection on it.
Previously, I had information that the problem was a cold-solder joint, but not which one. So I had already resoldered every connection on the display panel - to no avail.
This is great information - the last quote I had was $200. It took about 30 minutes to do it myself.
One caution - I could not have done it without a magnifying light. The connections are too small.
Thanks again for this info!
Winford
Old 07-06-2002, 11:34 PM
OneShotBandit OneShotBandit is offline
OneShotBandit is starting off with a positive reputation.
Well I guess I'm not as smart as some of you. My '98 XLT Radio,
cassette, CD player display went out & I had Ford exchange it at
$280.00!:-X23
Old 07-08-2002, 12:08 PM
shihtzupoodle shihtzupoodle is offline
shihtzupoodle is starting off with a positive reputation.
Hi
I too have a 1998 Ford Explorer Sport model with a combo radio/cd system (that came with the vehicle) and in the last week the LCD display has disappeared. The radio and CD player works fine except you don't know what time it is, you don't know what radio channel you're listening to and you don't know what track your on on your CD. I see from reading the messages that the solution is to remove the radio and do some reconnecting, but, when you removed the radio, aren't you worried about damaging the moulded dash that its set into or is it easy to remove. Any tricks or is it straight forward? Thanks for you reply in advance, I now have to search out and see if anyone has problems with their center armrest, drink holder...mine broke.
Margaret
Old 07-08-2002, 06:17 PM
mgazak's Avatar
mgazak mgazak is offline
mgazak is starting off with a positive reputation.
Taking a stereo out of a 95-01 dash of an Explorer is a cinch. All you need are the two din radio pullers (can't think of the correct name). Any store that has car stereo equipment should have them. They are 'U' shaped and are inserted into the holes on both sides of the stereo. When they don't go in anymore, push both of them towards the outside of the car and pull the stereo right out. It slides out fairly easily and won't harm the dashboard at all. The soldering is the part I wouldn't trust myself with. Not a problem for me, though, I put in an aftermarket unit.
Good Luck!
Old 07-09-2002, 08:49 AM
duketter duketter is offline
duketter is starting off with a positive reputation.
If you are think of replacing the system or have a question about it, I would just replace the old stereo system if you can afford it. Aftermarket stereos sound much better and you will be more satisfied with them. On the explorer it is a cinch to swap the old stereo with a new aftermarket stereo. Just use the din tools to pull it out and buy some wiring harnesses and hook up your new stereo. A good place to go is www.crutchfield.com . They give you the wiring harnesses and dash kits for free when you buy a car stereo from them and give great directions with the kits too. It really is easy and anyone can do it.
Old 07-11-2002, 01:36 AM
bigmac24 bigmac24 is offline
bigmac24 is starting off with a positive reputation.
I have been unable to get to a working URL with the radio fix. Can someone please re-post it? Any help is greatly appreciated. This problem with the display not showing up, is driving me crazy!
Thanks,
mc
Old 07-11-2002, 01:38 PM
winfordr's Avatar
Here is the url: http://www.shareamemory.com/radio/
I used this information, and posted that I had repaired my radio.
But, unfortunately, it was temporary.
At least this article pointed me to the defective area. It's the small board described in the article which is accessible by removing the display panel and top cover, then taking out the one screw which goes through the heat shield. (also untwisting the metal tabs - which I got tired or messing with so just left them straight).
I finally, after resoldering several times, put the suspect piece back in the radio without the rf shield, and was able to duplicate the symptom by pressing on the toroidal filter. So, I totally removed the filter, found some breaks in the foil under it, repaired them, then replaced the filter(toroid). But, in doing so, either I broke off one of the surface mount resistors, or it was not connected properly. Anyway, I had to replace it with a conventional type resistor.
Now the display works most of the time instead of some of the time.
I will attempt it again, after I catch up some slack on other issues.
Too bad someone doesn't sell a new module to replace the problem one.
Winford:-)
Old 07-12-2002, 12:58 PM
djrrl djrrl is offline
djrrl is starting off with a positive reputation.
I had the same problem with my 98 explorer. The problem is internal to the radio. I am a techinician by profession. After acquiring the diagrams I found that the Power Supply and Oscilator module gets very hot to a point the circuit board become discolored. I feel it could be poor thermal management due to a poor design. I took mine apart and found some poor solder joints as a result of the internal heat. After resoldering the joints the radio display has worked fine for a year. A gentlemen at Omicron Electronics in Carrollton Texas help me some with drawings. If you are not a competent technician this will cost bucks to resolve. Good Luck!
  #28
Old 07-12-2002, 01:24 PM
winfordr's Avatar
I would like to know if I could buy a new power supply module for the display. I have asked some of the repair facilities and they all want me to send my radio. I am too stubborn. I will buy another one first.
In the mid-70's I had a tv repair business. I have designed and built circuit boards, even to the extent of hand masking and etching. So I want to be able to do this myself. My problem is the board I have (I think) has a bad module on it.
Winford
  #29
Old 08-21-2002, 12:17 AM
jhawk09 jhawk09 is offline
jhawk09 is starting off with a positive reputation.
The stereo is easy to remove and the website www.shareamemory.com/radio/ even tells you how to engineer the tool out of a clothes hanger to remove it.
My center console broke also. It "popped" off, not actually a break in the plastic. If this is what happened to yours, let me know and I can tell you how to fix it.
Joe Hawk (jamey-hawk@uiowa.edu)
  #30
Old 09-03-2002, 09:29 PM
duharris duharris is offline
duharris is starting off with a positive reputation.
Check out a fix for this problem at:
Regards,
D Harrison
Will RDS CD player from Explorer work in my Ranger? 1998Ranger25L153CID Ranger & B-Series 7 08-03-2016 09:37 AM
No display on radio sdswan Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 8 12-22-2015 12:59 AM
bolt pattern speedracer54729 Ranger & B-Series 2 03-01-2015 11:56 PM
1998 explorer fuel pump assembly r&r 2000+1998 Explorer, Sport Trac, Mountaineer & Aviator 1 02-15-2014 12:46 AM
will a 2001 ranger transmission fit in an 198 explorer eric_engler Explorer, Sport Trac, Mountaineer & Aviator 0 01-04-2014 03:38 PM
Tags
1998, 1999, 2083813831forumsshowthreadphps953f262d7deded414020 433519f151aethreadid39115, 2083813831forumsshowthreadphps953f262d7deded414020 433519f151aethreadid39115radio, dial, display, explorer, explorerradio, f150, f87f18c868ad, fix, ford, mach, problem, radio
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
