Manual Transmission Identification
Old 06-27-2004, 01:59 AM
Sgt_Pepper17's Avatar
Sgt_Pepper17
Sgt_Pepper17 is offline
I have an '80 F150 with a 302. I bought it with a C4, however, it burned up due to a lack of kickdown. I put in a different C4 with a kickdown linkage this time, however, the pump went out on this one. So.... I'm puting in a manual. I have the ability to do so, and a donor truck that I got for free with a manual (pretty lucky hu?) So, I was wondering what transmission was in the donor truck. Actually if someone could tell me where I could find a chart that I could use transmission tags to ID transmissons by, that would be great as I've ran into ID problems in the past too. The truck's transmission code is RTS. My buddy has a manual transmission too and it's code is FOG (at least I think it is.) Thanks for any help.
The Sarge
Old 06-27-2004, 02:30 AM
rhodie's Avatar
rhodie
rhodie is offline
I believe its a TOD t-170. No external linkages, no drain plug, shifting pattern as follows:
1 3
2 OD R
Here's a link you can see:
http://www.motivegear.com/tech_info/...nny_guide.html
Old 07-01-2004, 12:05 PM
Sgt_Pepper17
...and the other transmission
I found that one on the same page maybe 15 mins after my first post, but thanks anyhow for the reply. I can't figure out what the other transmission is though. If anyone can help me with that I'ld really appreciate it. It's a side loader, and has an aluminum tailshaft and bellhousing. Thanks.
Old 07-01-2004, 12:25 PM
82F100SWB's Avatar
82F100SWB
82F100SWB is offline
A side loader with an aluminum tailshaft in a truck is most likley a three speed. 2 shift rods or three?
Old 07-01-2004, 12:29 PM
Sgt_Pepper17
It's got three shift rods, that's why I think it's a fourspeed. My buddie's got the shifter linkage, I haven't seen them, and he told me at first that it was a fourspeed too. Thanks
Old 07-01-2004, 01:16 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,595 Likes on 1,300 Posts
Side loader 4 gear sounds like a Borg Warner T10?
Ford 3 speed, 4 speed and 4 speed OD are top loaders. Check out David Kee at http://www.4speedtoploaders.com/
Check ID charts.
Also www.5speeds.com for info.
fordboy300
11-09-2016 08:00 PM
hillcountryflt
05-09-2016 08:00 AM
abyars111
13
08-22-2013 10:33 AM
PapaBearYuma
04-01-2012 12:25 AM
nlareau
10-01-2011 12:45 PM
Quick Reply: Manual Transmission Identification
