Usually the products are roughly priced the same...with boxes they are all over the map on pricing...
__________________
Administrator
tim.lamkin@internetbrands dot com
Life is not only time……paradoxically, it is the denial of time!
What lies behind us and what lies before us are tiny matters compared to what lies within us.
According to the tech I talked to at Bullydog when I first started researching this months ago, they were making the chip FOR Quadzilla at the time. I wonder at this tho, because Quad has a speed delilmiter and Bullydog doesn't. It's been more than a year and all this stuff was for an 03 and very new. Another consideration is if your vehicle is still under warranty and what kind of codes will be left with boxes versus programmers--if that really matters--
I have to admit as a new user and looking for the right product I got a lot of help from the welcoming committee here at FTE. I know how to make horse power in a naturally aspirated engine but I was like a school girl thinking about her first prom when I started researching all the choices and not knowing much about electronics.
My research came down to EDGE products and PREDATOR. I was looking for a plug and play with the abilities to clear codes. EDGE is the best product in fuel boxes, but listening to the elders in FTE brought to my attention other things I never thought about.
I have the PREDATOR and love it because it is simple and easy to use even for me. If a trip to the local Ford dealer is ahead, no problem, no wires, and easy to remove.
I'd love to get my hands on a Predator, but unfortunately they don't work with my current flash. The truck still has the June 03 flash in it and it runs like a champ! A little smoke on startup every now and again accompanied by obligatory rough idle, but after a few seconds, it all smooths out and runs great. PLUS, I still have my pilot injection! :woot! So no reason to get flashed.
Guess I'm (stuck, lol) with having to get a box. SO this thread is rockin' to me! All the more info to add to my research as to which box to get. Dyno sheets help the best though!
__________________
2003 F-250 6.0L Lariat, FX4. ZooDad Mod, 4" Turbo back exhaust, Diablo Predator, and another little tuner juuuuuuuust for me!
Haven't tried it yet. But Bob isn't on the Oct 03 reflash?? I might have to look into it then. Motorhaven has a return policy on that sort of stuff, don't they? Either that, or I could make up something to get my truck reflashed. Either way, guess it's time to call Motorhaven.......hmm.
__________________
ebony
my 18th mile time is right abou 9 sec 4wheel launch. i was a little hasty to get out and program the six gun. never really did the whole prosess.i need to find the time to reprogram it.start and stop in every setting is hard on the brakes. i need to go out bout 2 in the morn when there is no traffic. thats what banks says i need to do. well hope that helps
max
03 250 sc 6.0 banks six gun.
ps my son had it out yesterday and beat a duromax by 2 lenghts. he had the six gun exhaust,innercoller, and cold air intake so much for the chevys
are you guiys sayin that i should make my own "system" i was reading that it is best for an exhaust system to go right up to the turbo when replacing the tubes.so i was thinking exhaust, predator and some kind of intake
Just a quick note, after I installed a new Banks Monster Exhaust from turbo-back, I would say do it!. The new down pipe on Banks in mandrel bent. After I took my factory down pipe off my 04, F250, Lariat, Fx4, I removed the heat shield covering from it. I could not believe what I saw. The pipe looked like a couple of monkeys bent it with sledge hammers. If you don't look at it, you probably won't believe it. With covering on it looks fine.
I've seen a lot of 4" ss exhaust that all look great for bends that cost a lot less than I paid for my Banks. Just installed a Juice with in-cab controller & cat "test" pipe. All works great.Just wanted to add my input.
I see on the superchip they say the high level gives 150 and the diablo gives 100 gain. From reading what you guys are seeing, it seems that one of the numbers may be wrong. Thought?
