Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-25-2004, 10:53 PM
rawdawg rawdawg is offline
Garage is empty, add now
rawdawg is starting off with a positive reputation.
Unhappy Rear end tag decode? WCR-R1 3.50 6BA 782
I dont see this tag number listed in the reference they have on this site and was wondering if somebody could clue me in . Thanks
  #2 (permalink)
Old 06-27-2004, 12:45 PM
grclark351 grclark351 is offline
grclark351 is gaining momentum as a positive member of FTE.
what year is it? i have the 72 shop manuals, sometimes the codes are good for a number of years. it looks like a 3.50:1 open gear, what other info are you looking for?
  #3 (permalink)
Old 06-29-2004, 11:47 AM
I was wondering if it was a posi. Thanks, when I jacked up the rear, both wheels spun the same way.
Tony
  #4 (permalink)
Old 06-29-2004, 06:08 PM
not by the tag, but anything can be in there. if it was an original tagged Trac-Loc it would give the ratio as 3 L 50. could be someone put a Trac-Loc carrier in and replaced the tag to let whoever know what gear is in it? or could be someone did a five cent posi? this is just shimming the center tight by putting an extra shim behind the axle side gears. if you jack one tire off the ground, with the trans in park, how hard is it to turn the lifted tire? it should turn with considerable resistance if the clutches are good. listen for chatter or any other noise when it breaks loose.
Tags
1978, 3l50, decode, decoding, end, ford, located, numbers, posi, rear, tag, trans, truck, wcr, wcrr1
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
