I need HELP !!!!!!! - Ford Truck Enthusiasts Forums
Ohio Chapter Join Chapter, Leader: RUNVS
I need HELP !!!!!!!
Old 06-24-2004, 08:19 PM
trigun7469 trigun7469 is offline
trigun7469 is starting off with a positive reputation.
I need HELP !!!!!!!
hey locals I have a couple questions, my first question is there is a squeking noise near my driver side, I think its my suspension but not a 100% sure, I thin my exhaust is making a funny noise as well not sure if that is contributing???? my last questions is about the local area places where i can get the supplies needed, i live in the cleveland area so anywhere local would be nice, family owned will be cool as well, not to found of the autzones.
Old 06-25-2004, 03:29 PM
F2504x4's Avatar
F2504x4 F2504x4 is offline
F2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud ofF2504x4 has much to be proud of
hi. could you give some info on your truck, yr make model engine?
also go into your usercp and fill in the signature with your trucks info.
it makes it easier for us to help you out..also put your city in the location section......thanks
Old 06-25-2004, 11:02 PM
1997 Explorer
4X4
2dr Sport
5 speed
84,xxx
Items added in the last month:
Keyless entry Alarm system
10 disc CD player
Brand new Brembo rotors all around
Brand new High Performance brakes
Brand new park brake and springs replaced
Brakes bleed and replaced with Motul Brake Fluid
Old 06-25-2004, 11:37 PM
F2504x4's Avatar
okay that helps ....you might try spraying white grease on all the rubber parts of the suspension...salt dries out those parts...
i don't know much about ex's but maybe these guy can help..
http://www.ford-trucks.com/forums/forum32/
just click the link....they will be glad to help you out ...thanks for stopping by...don't forget about us'..
and i'm sure someone from the cleveland area will chime in about some good shops....
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
