96 explorer with trouble code 420
Have set this code two times in about 500 miles.
I have a code scanner for obd-II and cleared the code, then
my son drove the car, and about 3 weeks and 500 miles have brought
the code back. The hand scanner says code 420 has something to do with the catalytic converter being below minnium threshold performance.Does this mean the converter needs to be replaced or is there a possible problem with the last o2 sensor? How can I test for the right fix? If the converter is bad how much do they cost.
The truck has 124000 miles on it.
>H
>in about 500 miles.
>then
>miles have brought
>How can I test for
>do they cost.
>it.
Are you getting any other codes ? Have any of the O2 Sensors been replaced ? Dont condem the converter simply because the code mentions it . The O2 sensor behind the converter is likely telling you something upstream is causing the problem . W/o the diagnostic routines & pinpoint tests its hard to make a diagnosis with any certainty .
>in about 500 miles.
>then
>miles have brought
>How can I test for
>do they cost.
>it.
No other codes set.
Truck has original sensors as far as I know.
Good driveability.
Have only owned vehicle for 6 weeks, but am sure of it's history as having had a good home and solid maintenance routine as far as lube and filters go.
Has 15 to 16 mpg milage.
Seems it may have a very very minor irregular idle speed.
Am using gasohol as it is only fuel available in Mn.
Good driveability.
[font size="1" color="#FF0000"]LAST EDITED ON 04-Jun-01 AT 11:22 AM (EST)[/font][p]I'm having similar issues w/ my '96 Explorer. I also live in MN, hope it's not a fuel problem as the truck was originally a GA vehicle.
My "Check Engine" light has been illuminated for some time now and I thought they de-coded it as 402, it may have been 420 however. They said it was the RGC valve. I did have a Ford dealer replace the O2 sensor last February (shouldn't they have replaced the valve at that time, too?) when this issue started. The light came back on a short time later.
I also have noticed a little "wet" exhaust coming from tailpipe when I idle in one spot for a minute or two. Any one help? Thanks.
CATALYST MONITOR AND EXHAUST SYSTEM PINPOINT TEST HF
General Information
Pinpoint Test HF is used to diagnose the following items:
· Exhaust System pipes (both front & rear)
· Catalytic converter
· Exhaust system muffler
· Exhaust system tailpipe assembly
· Exhaust manifold
· Wiring harness circuits to both cylinder Bank 1 and Bank 2 downstream Heated Oxygen sensor(s)
Code Descriptions
DTC P0420 / 421 – Cylinder Bank 1 catalyst efficiency below acceptable threshold.
DTC P0430 / 431 - Cylinder Bank 2 catalyst efficiency below acceptable threshold.
NOTICE
Prior to starting this test procedure, verify that the customer has not refueled the vehicle with leaded gasoline or experience high engine oil consumption.
NOTICE
Complete the spark timing check portion of the Quick Test prior to proceeding with this repair chart as the spark timing may be retarded below the normal setting. If it is, exhaust gas temperatures may increase which could decrease the efficiency of the catalysts.
FLOW CHART DOWNLOADED IN MS WORD
Doug
General Information
· Exhaust manifold
Code Descriptions
NOTICE
NOTICE
Doug
I recently had a code 420. I looked in my Haynes manual and it did not offer much help. I reset the code and it has not reappeared. By the way, my 1996 Ford Explorer XLT has a V6 and 108,000 miles. Were you able to further diagnose and remedy your code 420?
I have a 96 XLT 4x4 with 110,000 miles and had the same problem - I would reset and the code would return not too long after - A friend of mine suggested replacing the plugs & wires and I did - I havn't had the code return yet (knock on wood) for almost 9 months now.
bkollmeyer
1999 to 2016 Super Duty
03-19-2015 06:09 AM
jdstudski
16
07-27-2014 12:09 PM
Ford79
02-10-2011 06:10 PM
