300 I6 is backfiring
My 1986 F150 w/300 six backfires when I let off on the gas it's a real short POP! and at faster speeds it'll occasionally do a full blown BANG. I have replaced the manifold gasket, muffler, and tail pipe because they had leaks but it still does it. Need to fix it because it bloated my muffler. I don't want to do the same to the new one.
Could it be the cats? I have a book that says one cause of backfiring is improper valve timing. Has anyone had this problem?
I put a glass pack on it (Sounds Great, love goin through town an scarin people) but I don't want that embarassing backfire.
1986 F150 300 I-6 4 spd w/od 106,000 and still runnin strong
When you let off the gas after "getting on it" you have a momentary rich fuel mixture passing through the exhaust. If you air injection is supposed to cutout to prevent extra oxygen from getting with the excess gas when it's somewhere hot like in your exhaust manifold or CAT. As posted above, if you remove the O2, you remove the likelihood of explosion. Look into why the air pump is not "dumping" when your getting on the gas. You may have a stuck bypass valve. Removing the air pump's belt would be a good place to start narrowing down the cause.
OrangeRanger
16
10-09-2015 07:36 PM
allaboutcars101
03-17-2013 12:04 PM
tcbofade
06-14-2012 08:54 PM
nbfnwe
09-27-2007 03:40 PM
GoldenDually
01-17-2004 11:10 PM
